First post, by Yoghoo
Installed a Tapedeck 2c today on a Windows 98 pc and playing tapes works great. But while trying to record a tape to mp3 or wav I got the error in the screenshot below.
It will create a mp3 or wav file but it only contains a header nothing more. Using Tapedeck version 3.25 at the moment as that is the only version I could find.
Soundcard is an AWE64 (CT4520) and Winamp is installed (old manual said it's needed for recording; but I guess that's only for older versions of Tapedeck).
Anybody knows how I can solve this or has an older version of the Tapedeck software?
Reply 1 of 1, by Yoghoo
Seems it really does not like my AWE64. Tried everything including installing Windows 98SE instead of Windows 98, patching OS, different drivers etc etc.
In the end installed a second sound card (a Sound Blaster Vibra 128 CT4810) and now recording with Tapedeck works. As a workaround you can of course use something else for recording like WavePad which also worked with the AWE64. But that would be too easy. 😀
