First post, by FinalJenemba
Working on restoring a Legend 1148. The machine overall is in super nice shape. But of course there's been some battery leakage, fortunately it was only in one small spot, but that spot totally toasted an IC. It's a 74F151A chip. I can find datasheets for it all over the place, but cant for the life of me find a replacement. I've found similar chips, but nothing that matches exactly. Any suggestions for a replacement? Don't want to power test the machine till I get it fixed. Closest I can find is this AD variant on ebay, would this do the job? Posted this over on VCFF as well, fingers crossed someone has come across a similar chip before 🤣. Thanks!
Reply 2 of 9, by FinalJenemba
ChrisXF wrote on 2023-07-24, 22:41:
74F151ASJ 74F151A SOP16 5pcs/lot
https://a.aliexpress.com/_mN19W9s
That might do the trick?
Thanks! That does look like an exact replacement actually. I didn't think about Aliexpress. Someone over on VCFF recommended these as a TI made equivalent https://www.digikey.com/en/products/detail/te … 4F151BDR/562741
I ordered some of those for now just because its Digikey and I can get them in a couple of days vs Ali. But if they aren't the right thing I can fall back on those, thanks!
Reply 3 of 9, by BitWrangler
Basically with 74 series replacements you check the switching speed in nanoseconds, and check the fanout (number of other gates it can drive) and if it's better or same then swap away. F series were the best in the 70s, since then we've had ABT etc. A lot of Fs you can probably replace with AS but you gotta be sure that extra half nanosecond ain't too important.
Reply 4 of 9, by KNagle
I just wanted to add that I'm doing the EXACT same thing right now to my PB Legend that was our first family PC when I was a kid.
I asked this very question in a couple FB groups I'm in and was pointed to that exact eBay listing as a replacement. I ordered them, and successfully got one mounted in place, however I still have a few tiny trace repairs to finish before I can test it out.
I'll report back when I finish on whether or not that chip worked, for posterity if nothing else.
Reply 5 of 9, by FinalJenemba
KNagle wrote on 2023-07-25, 05:12:
Interesting, well at least I know if the digikey isn't happy I can try that one too. Does anyone know whats this chip actually does on this MB? So we know what to look out for to see if its its working right or not?
Reply 6 of 9, by BitWrangler
Hard to tell, looks like it's Mux-ing a few lines off the PAL there and piping it across the board somewhere.
Reply 7 of 9, by KNagle
My issue is not being able to press F2 to enter the bios settings. I found a random blog while researching this topic from a guy who again was doing the EXACT same repair, and also had the exact same symptoms I'm having: keyboard is working but pressing F2 to enter the BIOS does nothing.
Pressing F1 to retry works fine, but it just repeats the error again, and holding a key while it's booting gives me the stuck key error, so I'm pretty sure the keyboard is working fine.
After replacing the chip and repairing the broken traces, his was back to working again and was able to access the BIOS settings. I'm hopeful this will work for me too, and I'd be done already if these wires weren't so damn small 🤣.
Reply 8 of 9, by FinalJenemba
KNagle wrote on 2023-07-26, 00:48:
That's actually quite helpful. I haven't even tried to boot mine yet, but once I do ill know that if F2 works then I did it right 🤣
