SATA to IDE adapters
First post, by squelch41
Hi,
I bought 2 SATA to IDE adapters on ebay which turned out to be defective (tried with 3 sata HDDs on 3 IDE motherboards in master and slave configs - no life).
Quality of manufacture is pretty terrrible as well.
I am debating rolling the dice again having got a refund but was wondeirng if people had good experiences with these or not?
I need one with master/slave selection as my 486 only has one IDE channel and on my p3, I only have one spare channel.
The (dead) ones I got have a chip as shown marked DOF B76ZZ0041 for which nothing comes up on google for datasheets etc.
Anyone had any good experiences with these adapters?
(want to go ide-sata as have some spare sata disks)
Thanks!
V4P895P3 VLB Motherboard AMD 486 133MHz.64mb RAM, CF 4Gb HDD,
440bx MSI 6119, modified slocket , Tualitin Celeron 1.2Ghz 256mb SD-RAM, CF 4GB HDD, FX5200 gfx
386sx 20MHz ICL NB386s laptop, 4mb RAM, modified bios with XT-IDE, CF 512mb, 387 FPU
Reply 1 of 17, by Joseph_Joestar
I've had mixed success with those generic adapters. Some older VIA-based motherboards don't like the JMicron chip which they use. Intel-based motherboards seem to work fine with them most of the time.
If you want an alternative, StarTech adapters are more expensive but they do provide better compatibility since they use a Marvell chip. Phil reviewed them recently in this video.
Reply 2 of 17, by oh2ftu
Use startech.
Reply 3 of 17, by texspex
I have one of those adapters which didn't work properly.
Reflowing the SATA and IDE connector solderpoints with leaded solder and removing R5 (which links pin 34 to ground and might mess up the PDIAG signal) it started working. Now the PDIAG signal goes via R4 to pin 34 and the bridge chip controls it.
Haven't had time to do extensive testing though.
There's a nice article on hackaday about reverse engineering the JM20330 evaluation board: https://hackaday.io/project/186809-m2-sata-to … rse-engineering
It seems from the original circuit that one should not populate both R4 and R5 (R15 and R16 on the Eval Board) at the same time.
And I do believe this DOF chip and JM20330 are the same.
But if you want something that just works then I'd also say Startech adapter is the way to go.
Reply 4 of 17, by squelch41
Thanks - out of curiosity gave pulling the r5 resistor out a go but still dead.
Sounds like startech or a bigger cf card is the way to go
texspex wrote on 2023-07-26, 22:33:
I have one of those adapters which didn't work properly. Reflowing the SATA and IDE connector solderpoints with leaded solder a […]
Reply 5 of 17, by creepingnet
I'm using a Generic KingWin ADP-06 I bought at Fry's just before they closed in Silicon Valley. I've been using it for the last 4 years in my 486 and it's been great (but I have Dual IDE). I don't think it has any jumpers though, just a thought. However, I have had AMAZING luck getting SATA drives working on that system and a few of my other 486s using that adapter. It runs a full 256GB SSD on a PTI-255W VLB controller card, so if you're running ancient stuff like I Do you might want some kind of high-speed IDE controller to use with it. I really should try it out with some other computers - including my cranky old NanTan FMA3500C (if it'll run on that, it'll work on anything).
~The Creeping Network~
Reply 6 of 17, by texspex
squelch41 wrote on 2023-07-27, 20:41:
Ah, too bad. Might be a faulty DOF chip then.
It is a hit and miss sometimes with these cheap adapters.
Reply 7 of 17, by drew2020
Came across one those adapters at Microcenter yesterday and bough it. It's by Vantec. Haven't tried it yet. Planning on using it with a Win95 build.
Reply 8 of 17, by lti
That's the first time I've heard of a JMicron-based converter working at a higher speed than ATA33/UDMA2 on a VIA chipset. I'll have to see if there's a difference between the converters or if later chipsets work better.
Reply 9 of 17, by ElectroSoldier
Stay away from the cheap adapters.
Ive got two Startech ones and never had a problem.
They do some nice quality stuff.
Reply 10 of 17, by Shnite
However, in his project, the author left resistor R7 idle.
Reply 11 of 17, by Shnite
Joseph_Joestar wrote on 2023-07-26, 11:19:
I have a SATA to Slim IDE 50 adapter based on the B76ZZ0041 chip.
On Linux (Lubuntu), it works in UDMA6 mode with the setting libata.force=80c.
On Windows 7? Unfortunately, only UDMA2.
The southbridge is VIA VT8235.
Note that on Linux it operates in UDMA6 mode through the Slim IDE connector (!!!), which isn't even designed to support anything above UDMA2 — the 34th pin isn't connected on the board at all.
Reply 12 of 17, by lti
Shnite wrote on 2025-04-20, 13:06:
I have a SATA to Slim IDE 50 adapter based on the B76ZZ0041 chip. On Linux (Lubuntu), it works in UDMA6 mode with the setting li […]
I missed this post a month ago. Since laptop hard drives usually plug directly into the motherboard with no cable at all, the board is designed to always report that an 80-conductor cable is connected.
I'm going to have to remember that Linux parameter if I ever decide to run ultra-lightweight Linux on one of my IDE-only machines (something like antiX or Tiny Core). I was once able to force higher ATA modes in Windows 98, but I don't remember what I did now (and that OS doesn't need the extra disk performance anyway).
Reply 13 of 17, by Shnite
lti wrote on 2025-05-31, 01:48:
You can also increase the speed in hardware. If you apply GND to the 46 pin of the B76ZZ0041 chip.
Reply 14 of 17, by lti
Shnite wrote on 2025-05-31, 07:46:
Is that chip pin-compatible with the JM20330? If it is, pin 46 is PDIAG, and grounding it on my JM20330-based converter didn't change anything. I even tried connecting the FXDMA pin to 3.3V and messing with the mode pins, and it still ran at UDMA2.
Reply 15 of 17, by Shnite
lti wrote on 2025-05-31, 17:52:
Did you short circuit on the chip or on the outputs?
Reply 16 of 17, by lti
It was on the chip. Also, I was using it in a laptop, where the PDIAG pin on the IDE connector was never connected to anything. It's designed so the IDE controller always thinks an 80-conductor cable is used because there's no cable at all.
Reply 17 of 17, by Shnite
lti wrote on 2025-05-31, 18:30:
Do you have a photo of how you made the short circuit on pin 46?
Do you have a diagram of the laptop for IDE and for Slim IDE?
On my Acer Ferrai 3200 (2003) this is how IDE is implemented.
The attachment Снимок экрана 2025-04-17 в 08.42.48.png is no longer available
