First post, by gryffinwings
So I picked up an old HP Pavilion 6350 socket 7 desktop at the local swap meet for $20 USD, condition unknown, but everything was there and didn't see anything unusual.
I have gotten it home, plugged it in and hooked a monitor to it, but all it does is power on for split second and turns off.
So I unplugged all unneeded things that were connected to the power supply and I do get it to post once, so I know that the motherboard, cpu, and ram are fine.
So now I need a suitable power supply for this rig, now while it is ATX, the form factor is a little different, I was wondering what options I have.
    464.78 KiB
    548.09 KiB
    526.39 KiB
    590.78 KiB
Main Computer: Custom - Intel 12900K, Asus Nvidia 3080 Ti, 64 GB DDR5.
Retro Computer: Packard Bell Legend I - AMD 286, 640KB RAM
Retro Computer: Dell Dimension 4400 - Pentium 4 2.8 GHz FSB 400 MHz, ATi Radeon 9600XT, Sound Blaster Live!, 768 MB RAM.
Reply 1 of 1, by Horun
Best option is to buy a refurbed or tested used one. Before anything I would use a voltmeter and test each voltage AND pull it out and use another ATX PSU that you know works as a test. Having the board POST once is no guarentee it is a stable board.
If board still does not boot easily then it a board issue.... be sure to use a ATX that supplies -5v as the original does (it may be required),,,,
