First post, by the Vrb
When I open DOSBOX it tells me "you are running in 24bpp mode, this will slow things down!"
Does someone know how to change to 16 or 32?
Reply 1 of 1, by Kippesoep
Assuming you're running Windows: right-click on your desktop, choose "properties" to bring up the display properties, choose the "settings" tab and select the bit depth in "color quality".
My site: Ramblings on mostly tech stuff.
