First post, by terrormiah
Just started playing around with a pentium 233mmx system and i'm encountering a weird bug i've never had before, basically whenever I have the DOS cdrom drivers loaded into my config and autoexec files windows start up slows to a crawl and the system hangs whenever i launch My Computer or even look at the D drive in explorer but if i remove all lines regarding the CDROM drive everything is normal, except of course i don't have cdrom support in DOS. Current config files look like this:
I've tried both OAK and VIDECDD drivers, VIDECDD seems to slow everything down even worse than OAK did
Autoexec.bat:
SET SOUND=C:\PROGRA~1\CREATIVE\CTSND
SET MIDI=SYNTH:1 MAP:E MODE:0
SET BLASTER=A220 I5 D1 H5 P330 E620 T6
set path=C:\Windows\COMMAND;C:\
LH C:\Windows\COMMAND\MSCDEX.EXE /D:MSCD0001
Config.sys
DEVICE=C:\Windows\HIMEM.SYS
DOS=HIGH,UMB
DEVICE=C:\Windows\EMM386.EXE NOEMS
DEVICEHIGH=OAKCDROM.SYS /D:MSCD0001 (edited)
