First post, by Will_90
every game i try to put sound it keeps stuttering, like making a popcorn
sound blaster, adlib, roland mt-32........everything
i have already tryed to change the cycles and frameskips but don't work
what can i do??????
the pc is a p3 494 mhz (overclock), gf2 mx400, mobo asaki p3-141, 256 mb with Wxp sp2
i tried to run on a p2 400mhz, 3d rage lt pro, 128 mb and it's just the same
what do i have to change in the config file???
don't know......plz help
Reply 1 of 3, by eobet
Press Ctrl + F11 until the stuttering stops. I play at around 2000-4000 cycles on my 1ghz laptop (compared to around 12000 cycles on my stationary computer)...
...looking at your specs, it seems that you should run at around 200-400 cycles, but that is perhaps too slow to keep up with the sound, on the other hand.
My recommendations would be to buy a new computer, perhaps one that isn't 10 years old, and try on that one instead. Or simply uninstall XP and install DOS on the one you got. Seems silly to emulate DOS on a machine that's from the DOS era, if you ask me. 😀
Reply 3 of 3, by `Moe`
Your system looks a bit like my old laptop. Try these recommendations, but DON'T EXPECT TOO MUCH:
http://dosbox.sourceforge.net/wiki/index.php? … eDemandingGames
Many non-action games are playable on such a setup. But forget 3d shooters.
