First post, by bostonvintage1993
- Newbie
Hi all,
I am currently trying to configure an Ultrastor 24F SCSI EISA card in my Anigma motherboard EISA system. I have the EISA .CFG file and I successfully loaded it using an EISA configuration utility, however no matter what I do/change I get an error message on startup - "Disk Controller RAM Error at 3E00." I looked it up and the manual says to change the BIOS address in the EISA configuration utility if this error occurs. Well, I changed the BIOS address to all available options in the EISA configuration utility and I get the same error every time. Only when I disable the BIOS address in the EISA configuration utility does the RAM error go away; but then the card still doesn't work. I'm currently at a loss and could really use some help to get this card up and running. Any advice would be greatly appreciated, thanks!
Have any questions related to Gateway 2000? I'm here to help - send a PM!
