First post, by SmartSailorTV
Welcome All,
This is my first Windows XP project - "Retrozaur" aka "Retrosaurus".
Purpose of this project: Fastest AGP Gaming Computer in the entire world. I will use best hardware components to reach my goal . I started to buy pieces of the hardware long time age, now its time to build real machine. 
Components in use:
Motherboard: ASRock AM2NF3-VSTA Bios : P3.30-15B; Brand new – shop sleeper, price: 239PLN/60USD. Fastest stock processor for AGP(Phenom 2 x4 980BE), DDR2 1066MHz, SATA+EIDE+FDD;
CPU: AMD Phenom II X4 980 BE 140Pln; Fastest stock processor for AGP platform. Unfortunately my piece of 980BE bought from Allegro refuse to do any overclock. Any attempt for overclock cause freezes or restart of the system.
RAM: 2x 2GB G.Skill DDR2 F2-8500CL5D-4GBPI-B 105PLN/26USD; 1066MHz without any problems.
HDD: SATA Crucial M4 SSD 512GB 220PLN/55USD;
GPU: PowerColor ATI Radeon HD 3850 512MB GDDR3 AGP 255PLN/64USD; Great card, super overclocking.
CASE: BMW PC CASE 😀 Limited Edition PC Case 115PLN/29USD;
PSU: Chief GPS-450A 49Pln; Max Watts reading from the socket < 250W so 450W is more then enough 69PLN/17USD
CPU Cooler: SilentiumPC Spartan 4 100mm (SPC270) 47.04PLN/12USD ;
Blu Ray: Panasonic SW-5582-C 149PLN/37USD;
Sound Card: -18.08.2023 X-Fi Extreme Fidelity SB0790 replaced by Sound Blaster (CA-20K1-PAG) X-Fi SB0460+SB0250+remote control 250PLN/63USD;
FDD: MPF920 50PLN/13USD;
Speakers: Creative T20 100PLN/25USD;
Monitor: DELL 2007FPB 1600x1200px IPS 79PLN/20USD;
Competitor for the title:
Intel Core 2 Quad Q9650 LGA775, DDR1(platform limitation), HD3850. (correction: ASRock 4CoreDual-SATA2 supports LGA775, AGP, PCI-E, DDR and DDR2 667mhz ) .
    213.72 KiB
    RAM DDR2 G.Skill F2-8500CL5D-4GBPI-B
    468.84 KiB
    CHIEFTEC Chief GPS-450A
    323.24 KiB
    336.63 KiB
    412.12 KiB
    Panasonic SW-5582-C
Reply 1 of 17, by Horun
Good luck !
Reply 2 of 17, by shevalier
SmartSailorTV wrote on 2023-08-17, 02:36:
Sound Card: X-Fi Extreme Fidelity SB0790;
Congrats on the build, but let me be tedious.
But alas, SB0790 is not X-Fi, but only in name. It's a rebranding of Sblive! 24bit and Audigy LS.
Which are HBA (host-based controller), i.e. do not have any hardware audio processing. Only software in the driver.
It's far from an ultimate.
It's even worse than the Audigi 2 Value, which is a real Audigi with hardware sound processing.
When choosing, I recommend paying attention that real X-Fi always have a separate RAM chip.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Diamond monster sound MX300
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value
Reply 3 of 17, by SmartSailorTV
shevalier wrote on 2023-08-17, 02:47:
Congrats on the build, but let me be tedious. But alas, SB0790 is not X-Fi, but only in name. It's a rebranding of Sblive! 24bit […]
My main purpose for SB0790 is gaming, is it not ultimate for EAX in Win XP? What is best PCI Sound Card for EAX in Win XP???
Reply 4 of 17, by shevalier
SmartSailorTV wrote on 2023-08-17, 03:15:
EAX at HBA - software emulation by the driver on the processor.
https://en.wikipedia.org/wiki/Sound_Blaster_X … Fi_Xtreme_Audio
Real EAX - 2.0 only at EMU10K1 (Soundblaster), 4.0 at EMU10K2 (Audigy) and 5.0 at 20K1/2 (X-Fi) chips.
Reply 5 of 17, by H3nrik V!
CASE: BMW PC CASE 😀
Looking forward to seeing pictures of that! 😀
Reply 6 of 17, by acl
Just curious, never heard of this limitation.
Is it about 4CoreDual-Sata2 mainboard ?
Core2Quad and Extreme can run on DDR2 with this board
Reply 7 of 17, by SmartSailorTV
acl wrote on 2023-08-17, 19:35:
Just curious, never heard of this limitation. Is it about 4CoreDual-Sata2 mainboard ? […]
Thank You. I updated my description.
Reply 8 of 17, by Cosmic
Sounds like a pretty interesting build! Would love to see the results after it's complete.
What would the fastest non-bridge chip Nvidia AGP card be? I believe for ATI it's the X850 XT PE.
Reply 9 of 17, by nvllsvm
I pieced together a similiar system last year (same motherboard, CPU, and GPU). A great XP machine for sure!
I'd be interested to see what scores you get in 3DMark03. Here's what I got:
"Result": {
"24 sounds": "119.254699707 FPS",
"3DMark Score": "31621.000000000 3DMarks",
"60 sounds": "108.487274170 FPS",
"CPU Score": "2383.000000000 CPUMarks",
"CPU Test 1": "244.023529053 FPS",
"CPU Test 2": "45.874103546 FPS",
"Fill Rate (Multi-Texturing)": "10237.456054688 texels/s",
"Fill Rate (Single-Texturing)": "4929.051269531 texels/s",
"GT1 - Wings of Fury": "635.858825684 FPS",
"GT2 - Battle of Proxycon": "250.094467163 FPS",
"GT3 - Troll's Lair": "202.557464600 FPS",
"GT4 - Mother Nature": "211.567306519 FPS",
"No sounds": "132.721725464 FPS",
"Pixel Shader 2.0": "236.046707153 FPS",
"Ragtroll": "173.403503418 FPS",
"Vertex Shader": "153.899398804 FPS"
"Settings": {
"Anti-Aliasing": "None",
"Checksums Valid": "No",
"Comment": null,
"Display Changed": "No",
"Fixed Framerate": "Off",
"Force PS 1.1 in GT2 & GT3": "No",
"Height": "768",
"Invalid Score": "No",
"Max Anisotropy": "4",
"Max CPU Frequency": "3718 MHz",
"Max GPU Engine Frequency": "0 MHz",
"Max GPU Memory Frequency": "0 MHz",
"Max Run Length Deviation": "0 %",
"Min CPU Frequency": "3718 MHz",
"Min GPU Engine Frequency": "0 MHz",
"Min GPU Memory Frequency": "0 MHz",
"Min Run Length Deviation": "0 %",
"NullPS": "No",
"Post-Processing": "No",
"Registration Key": "N4LWE-T6HUX-8U4JB-28YLV",
"Repeat Tests": "Off",
"Texture Filtering": "Optimal",
"Vertex Shaders": "Optimal",
"Width": "1024"
"Version": "3.6.0"
Reply 10 of 17, by SmartSailorTV
I found some sound cards in my chest:
-Sound Blaster (CA-20K1-PAG) X-Fi SB0460+SB0250+remote control. I used this card in Win7, remote control didnt work but I am not sure was it hardware fault or drivers.
-ASUS XONAR DS/A with replaced amp for : LME 49860NA. I used this card in the past, best for music listening 😀 I remember that amp replacement give big boost in sound quality.
I have more models but looks like those 2 are my best for PCI slot.
    280.62 KiB
    390.26 KiB
    ASUS XONAR DS/A with amp: LME 49860NA
Reply 11 of 17, by shevalier
SmartSailorTV wrote on 2023-08-18, 21:18:
X-Fi SB0460
this, Asus also HBA.
At the same time, I would not recommend using 5.25 bay.
This one has mediocre performance, it is more for appearance.
PS. If X-fi is buggy, I would recommend replacing this largest capacitor here. This is the genetic disease of all PCI X-fi`s.
On some polymer, 3-6.3V with a capacity of 560-1000 uF.
    30.45 KiB
Reply 12 of 17, by acl
shevalier wrote on 2023-08-19, 06:15:
Does it affects most of these X-Fi cards ? What's the problem ?
I have the same card, also with the fron panel, and i must admit I only installed it for the look and it's not even connected.
Edit : there is normally a dissipator on the X-Fi chip iirc
Reply 13 of 17, by shevalier
acl wrote on 2023-08-19, 07:23:
Its affect ALL pci x-fi.
Usually the sound starts to break, then the card generally ceases to be initialized.
This is the main power capacitor DSP X-FI.
No capacitor - no X-Fi
The front panel has a headphone amplifier.
Very shitty quality.
And it is connected to a separate DAC, also of very mediocre quality.
Сreative`s came the idea what else to plug into the front panel - and let's plug in a headphone amplifier.
But what would be cheap.
Well, that's how it happened.
Reply 14 of 17, by acl
shevalier wrote on 2023-08-19, 08:37:
Its affect ALL pci x-fi. […]
Thank you very much for the details.
I'll keep that in mind if the card start to have issues.
Reply 15 of 17, by SmartSailorTV
Hi All,
After many boot failures, unexpected errors/power off`s, freezing screens and not so many blue screens, I was able to force GART to work with Catalyst 8.12 drivers. I had to install GART driver (downloaded from ASRock page) in Safe Mode and after this activity, Catalyst driver recognized GART as installed. It didnt work if I installed GART in normal WinXP mode .
Everything except FDD is in place. BMW PC Case looks really awesome, those blinking leading lights 😀
Brief summary of "Retrozaur" project:
1. Motherboard ASRock AM2NF3-VSTA Bios : P3.30-15B is compatible with Phenom II X4 980 out of the box. Same with RAM 2x G.Skill DDR2 F2-8500CL5D-4GBPI-B.
At this moment ASRock AM2NF3-VSTA is really problematic. Every attempt to restart PC (in windows or by restart button) results same as shout down system, computer refuse to boot, freezes and shouting down during recognizing of installed hardware. WinXP "Power Off" option itself works without any problem. I hope it is possible to fix it in bios settings.
When computer is started by button, it is happening(freezing and shout down) from time to time.
2. "Retrozaur" power usage from electrical socket (peak) -no more then 250W ("peak"observed during blue screen)
    181.47 KiB
    Power peak consumption
    252.66 KiB
    System Overview
    114.07 KiB
    BMW Car signal lights ON
    122.15 KiB
    BMW FWD LIGHTS
Reply 16 of 17, by SmartSailorTV
nvllsvm wrote on 2023-08-17, 21:08:
I pieced together a similiar system last year (same motherboard, CPU, and GPU). A great XP machine for sure! […]
"Result": {
"Settings": {
"Comment": null,
"Height": "768",
"NullPS": "No",
"Width": "1024"
"Version": "3.6.0"
Hi,
This is my score in 3DMark03, all clocks in stock settings.
upd. Score in 3DMark01SE attached.
    388.96 KiB
    3DMark01 47820pts
    505.71 KiB
    GPU-z Stock Settings
    627.74 KiB
    CPU Stock Settings
    662.43 KiB
    3DMark03v1 32036pts
    511.4 KiB
    3DMark03
Reply 17 of 17, by SmartSailorTV
Sorry for late update. Months ago my troublesome X4 980BE was replaced by X4 970BE - no more problems with freezing boot screen and OC (to keep X4 980BE clocks and higher). Sadly, after fresh Win XP installation I couldnt push GART and GPU drivers to work together (and I dont have much time) so I stopped to play with this project (temporary ) . I will try again this saturday, if I will not succeed then I will try next year .
Meanwhile(last week :p) i have bulit my next Ultimate WinXP Machine "Maximus", dual system computer (WinXP and Win10 64bit). Ultimate hardware : Asus Sabertooth Z97 Mark S White, 4790k, Ferra3RGB, GTX960 4GB White (final = 980Ti), SB0880, G.Skill Trid DDR3-2400 16GB (4GB x86), ZALMAN Z3 Plus White, PSU Corsair CX750F RGB White.
