First post, by envagyok
Hy everyone,
I bought some scsi caddys cd drives the other day.
With great difficulty I managed to get cd caddys for them, but they don't really want to work.
The cd drives:
The attachment 20230819_124741.jpg is no longer available
The attachment 20230819_124805.jpg is no longer available
The caddys :
The attachment 20230819_124834.jpg is no longer available
And the scsi card I tried :
The attachment 20230819_124926.jpg is no longer available
I also tried with another card.
The error is:
The texel and the yamaha when inserting the disc, after a few seconds it releases.
The Matsushita is a mechanical loaded, 8 cd drive is put into the system, one of them says when opening it to insert a disc, one of them shows a blank drive when opening it
All these drives are recognized by the windiws, they are visible in the device manager, I tried to set more IDs, terminate, etc., but no success.
The caddy is advertised as a commodore cd32, but I think it is the same as the pc caddy.
What do you suggest to try?
Do you know a mechanic who knows how to repair it?
I would really like to revive these as they are 91, 92 and 97 production, very rare, they have their place.
Thanks for any helping!
Reply 1 of 5, by dominusprog
The mechanical parts of CD-ROM are prone to breakdown and it doesn't matter if it's IDE or SCSI. You have to open them, clean the lens and gears, lubricant them, change the belt and see what happens.
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 5, by maxtherabbit
to the best of my knowledge, all cd caddies were the same so that's not the issue
Reply 3 of 5, by Horun
maxtherabbit wrote on 2023-08-19, 16:51:
Agree ! The single disk caddies are all the same AFAIK. Have a few 6x Plextors that use caddy and is same type as the Yamaha 4x.
BTW both those old cdroms have issues reading CDR unless they are the older 4x, 8x , or 1-24x media types (like the 1997 Imation Gold top with the blue-green dye), But can read any commercial made cdrom so far...
Reply 4 of 5, by FinalJenemba
Yes the caddys are the same across the board they were universal. The faults are just old drives needing maintenance most likely. As mentioned above cleaning/lubrication and new belts will fix most issues.
Reply 5 of 5, by envagyok
Thanks everyone.
I will try zo fix them.
