First post, by kant explain
In days of yore there was a spate of video cards, primarily PCI I believe, that allowed tinkering with video signals. Changing sync polarities and other sorts of weirdness.
Anyone know what I'm talking about? Anyone know which cards had the ability?
Reply 1 of 2, by fosterwj03
Many Matrox PCI cards have programmable DACs. The drivers allow you to specify signal parameters. That's how I get 1080p in NT 3.52 and OS/2.
Windows 3.1x, NT3. 5x, and OS/2 drivers hold these values in a text file called MGA.MON organized by monitor entries. You can modify the file, but you'll need to reboot the OS before using the changes.
NT 4 and Windows 9x use the graphics properties GUI to modify signal parameters. Not as easy to use, in my opinion.
Reply 2 of 2, by rasz_pl
Every car d does this to this day. I can go to my Nvidia control panel and configure custom resolution on 1660 right now.
Back in the day you could do that with Powerstrip https://www.audioholics.com/diy-audio/powerst … e-a-user-manual
https://github.com/raszpl/440BX Reference Design adapted to Kicad
