First post, by AlessandroB
I have an SBC that I should test but I don't have a backplain, since their price is not cheap, I thought I'd recycle an old 486 mainboard as a backplain by literally pulling all the pins except the power ones from the pin on the mainboard. Which pins should I keep in your opinion? clearly all those connected to the chipset of the MB will have to be disabled, thought to keep only the 5v 12v gnd -5 -12. Then by connecting an AT psu you can turn it on and give voltage to the sbc, do you think it would work?
