No signal…
First post, by Kouwes
I wanted to test this socket 7 board: Abit AB-PR5. Using a known working PSU and acer lcd monitor, all I got on the screen was: no signal.
Tried 4 different video cards, S3 Trio64, S3 Virge, Tseng ET4000 (all PCI) and a tseng ET4000 ISA.
No signal.
Also tried a ViewSonic VX924: no signal!!!!??
Any ideas?
Reply 2 of 6, by elszgensa
After checking for beep codes, that is where a POST test card would come in handy. Then check voltages across the board...
Also - stupid simple stuff like reseating RAM & CPU helped me a suprising amount of times.
Reply 3 of 6, by Kouwes
I couldn’t find a working speaker and I seem to have misplaced my beeper.
Weird, this board has been working fine until a few months ago where I swapped it for a board with a 233MMX.
The Abit board has a Pentium 166.
Reply 4 of 6, by Shponglefan
Kouwes wrote on 2023-09-04, 00:13:
You mean you swapped out the processor and it's no longer working? Did you check all the jumpers and make sure they are set correctly?
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 5 of 6, by Horun
THe ABIT PR5 does have multi vregs but the r2 manual says only 3.3 and 3.5v and one undocumented setting,,,,,a bit odd for a VX board to only support those voltages. The Asus VX board supports a wide variety..
Reply 6 of 6, by Kouwes
No, I swapped the entire board because it already had a 233MMX installed. Amptron PM-8600 iirc.
The PR5 seems very dead, not even a speaker signal.
I’m going to use it for soldering practice.
