First post, by CachoAlpuy
Hi, im starting to repair a Quadro FX 1000 which has no video output, no fan spinning and the computer beeps during post.
The only two things that i was able to check for now is:
1) There are a few missing caps in the bottom but i'm not to worried about those because those are bypass caps in parallel to other caps.
2) The linear voltage regulator marked in red in the photo gets really hot seconds after turning on the computer.
So i have a few questions in order to start diagnosing this:
1) Is it normal that this regulator gets hot?
2) What is this regulator supposed to supply? I couldn't trace the output to any of the components that i tested
3) What other things should i test?
