First post, by robert@exchangetest.
Hey Team,
I recently put together a Pentium 1 - 233 MMX. and a Rage 128 Pro. (All in wonder). I am only getting 20 FPS on Unreal and around the same on Quake 2 (GL), 3dMark99 is at 1276. Any ideas if that is about the correct performance? Would changing out the Video card make a difference? or am i just at a CPU limit here?
Thanks,
Robert
Reply 1 of 6, by Shponglefan
The Rage 128 Pro should yield decent performance in those games, but I suspect you're being limited by the Pentium MMX 233.
I'd suggest pairing the Rage 128 Pro with a Pentium II or faster system for better performance.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 2 of 6, by mwdmeyer
Your 3dmark 99 scores seems pretty good for a 233 MMX, so I would say you are CPU limited.
Reply 3 of 6, by robert@exchangetest.
I have another system that is a K62+ 400. That system should play those games pretty well, so i will try my rage pro 128 in there. I have heard of an ATI patch for Quake 2 (Does not help me here) - DO you know if there is an MMX patch ? I seem to remember playing quake 2 on a P233 - Though I may be wrong on that.
Reply 5 of 6, by vetz
robert@exchangetest. wrote on 2023-09-05, 22:56:
You may confuse it with the 3DNow! patch for AMD K6 CPUs. It will help you on your K6 system, but not on the 233 MMX.
I played Quake 2 on my Pentium 166 MMX with a Voodoo 1 back in 1997, looking back the framerate wasnt good, but I didnt complain.
Reply 6 of 6, by rasz_pl
mmx does nothing for games
Q2 plays fine on mmx, 20fps is what you perceived as fine in the nineties 😀
with gf2MX you could bump that to ~30fps
