Agp 4x doesn't turn on
First post, by TrueVegas
Hi all
is there someone who can tell me how to turn on AGP 4x for my Asus V7700 Ti on Asus TUV4X ?
I have installed drivers for VIA chipset and last drivers for my Asus V7700 Ti (GeForce 2 Ti) but i have always only AGP @2x.
I tried on different OS from Windows 98 to Windows XP
Maybe someone had same problems?
Specs:
- MB: Asus TUV4X
- CPU: Pentium III-S (Tualatin) @1400 Mhz
- RAM: 512 MB ECC SDRAM
- GPU: Asus V7700 Ti Deluxe
- Actual OS: Windows Me
Thank you in advance
-TrueVegas-
Reply 1 of 8, by kixs
Check in BIOS under Advanced settings -> Chip Configuration, what mode is selected for AGP.
Reply 2 of 8, by TrueVegas
kixs wrote on 2023-09-06, 19:40:
Thank you for the answear! I forgot to write that I set into the BIOS AGP 4x too.
-TrueVegas-
Reply 3 of 8, by Repo Man11
Reinstalling the Via 4 in 1 drivers in Turbo mode should do it. You can likely use Rivatuner to force it on as well.
Reply 4 of 8, by swaaye
Nvidia drivers often force 2X on chipsets not made by Intel. On AGP 4x chipsets other than Intel's, 4x is usually unreliable.
Reply 5 of 8, by TrueVegas
swaaye wrote on 2023-09-06, 22:42:
I think you are right. I found on asus.com a reg file to enable agp 4x with nVidia GPU but it doesn't work... 🙁
Maybe I have to change the graphics card or the motherboard...
-TrueVegas-
Reply 6 of 8, by swaaye
TrueVegas wrote on 2023-09-07, 12:38:
Other cards are likely to do the same thing. ATI has SmartGART which tests your motherboard and will often drop speed on non-Intel AGP 4x boards.
Being at 2X isn't really anything to worry about. The speed difference is minimal with games you will play on a GeForce 2.
If you want more solid AGP you want either an Intel chipset or to go up to AGP 8x motherboards.
Reply 7 of 8, by Repo Man11
Install Rivatuner, force AGP 4x, and test it in benchmarks and games. The difference will be likely almost unnoticeable, but that way you'll know for sure.
Reply 8 of 8, by Repo Man11
I recently picked up a computer with a Tyan S1854 with a P3 450, and spent this morning installing Windows 98SE. The video card is a Quadro 2 Pro, and I used the 45.23 driver. After running 3D Mark 2000 a few times, adjusting the memory and such to get a higher score, I thought I'd try AGP 4x. I set it to 4X in the CMOS settings, then used Riva Tuner to force it to 4x. It very quickly locked up when I ran 3D 2000, so I set it back to off. You never know for sure unless you try.
