First post, by boris_zmg
DOS reports 560K preventing me from loading large programs. I don't exactly know how the DISKONCHIP works but I believe that it may be loading into the conventional memory, reducing the available reported memory. The following is a statement from DISKONCHIP manual "After the BIOS identifies DiskOnChip 2000 as a valid BIOS expansion device, it executes the code stored in the boot block. The BIOS then loads the TrueFFS software from the flash memory into the host memory, delivering full disk capabilities to the operating system. This code is identical for all DiskOnChip 2000 capacities, since TrueFFS automatically detects the memory capacity of DiskOnChip 2000." Any clarification on this ?
