First post, by appiah4
I have a 386SX motherboard that POSTs fine to BIOS and boots fine to DOS using a floppy:
67.2 KiB
84.89 KiB
89.61 KiB
But when I attach a CF-IDE to the Primary IDE chain as master I get all kinds of garbled text after POST:
139.4 KiB
What would cause such weird behaviour? I almost feel like something is messing with the framebuffer somehow, but how? These are the default options in BIOS Advanced CMOS Settings..
181.96 KiB
Reply 3 of 14, by rasz_pl
not poor quality, simply ATA compliant.
Re: "Fixed" 386sx motherboard works but not with 16-bit VGA card Re: IDE/CF adapter causing screen corruption/missing characters
Reply 5 of 14, by appiah4
So I am guessing simply snipping pin 28 off the cf ide connector will do the trick?
Reply 8 of 14, by DerBaum
i have a 486 that really doesnt like 80wire ide cables and refuses to identify my cf card with it.
As soon as i use a regular old 40 wire ide cable it intantly sees the cf card.
Have you tried another cable?
FCKGW-RHQQ2
Reply 9 of 14, by appiah4
DerBaum wrote on 2023-09-11, 13:00:
A 40 stripe cable improves the situation somewhat, but there is still mising text.
Reply 10 of 14, by DerBaum
appiah4 wrote on 2023-09-11, 13:41:
Another thing i had problems while using cf cards is the auto detect of the bios.
I cant remember if i had to set the card from LBA to CHS or the other way around to make it work.
I also cant remember if i had missing letters. The main issue was that the system ran a "dir" fine when booted from a floppy but at a regular boot it hang while executing the drivers in autoexec.bat/config.sys .
In the end i configured the card manually in the bios and ran a low level format from the bios. Then Fdisk/format the card from dos 6.22 .
FCKGW-RHQQ2
Reply 11 of 14, by appiah4
DerBaum wrote on 2023-09-11, 14:28:
Another thing i had problems while using cf cards is the auto detect of the bios. I cant remember if i had to set the card from […]
This BIOS has no auto detect, the CHS values are set as Type 47..
Reply 12 of 14, by Jo22
Be careful with low-level format feature in BIOS.
It's dangerous under most circumstances. It's not like a soft format, at all.
The feature is there for 16-Bit MFM/RLL controller boards without an on-board BIOS.
- On 8-Bit systems debug was used to call low-level routines stored in ROM.
On an IDE HDD or a CF card, a low-level format can have unpredictable effects.
It can be that the firmware does weird things with the sectors, rendering the hardware unusable.
I rendered at least one CF unusable that way.
Reply 13 of 14, by Jo22
appiah4 wrote on 2023-09-11, 12:30:
Removing Pin 28 from the CF-IDE adapter did not fix the issue..
It's just an idea, but if it's not a hardware issue, then maybe it's a software issue?
The ATA-2 specification (Fast ATA, Enhanced IDE) changed a lot of things back then.
It could be that the HDD routines in the BIOS have issues with that.
Edit: https://www.os2museum.com/wp/how-to-please-wdctrl/
It's essentially IBM's AT Fixed Disk Adapter (WD1003 command set) and/or ATA (IDE, AT Bus) all they know.
That's why "HDD Auto Detection" is missing, also, it's a future ATA feature and not available on MFM/RLL controllers yet.
If BIOS is the issue, using XTIDE Universal BIOS could help here.
I had a similar issue in which it did, at least. It was a Schneider Tower AT with an outdated BIOS..
Whenever it was meant to boot DOS, it hung.
Anyway, this is just an idea, of course. 😅
Reply 14 of 14, by rasz_pl
I dont think DOS (therefore bios) touches disk while displaying "enter new date".
Just to make sure, storage still works? Try older CF card.
