First post, by keeno
I've recently purchased an IBM ThinkPad i Series 1720. I replaced the HDD and I put windows 98 on it.
I downloaded drivers from the following site:
https://thinkpads.com/support/Thinkpad-Driver … t/ddfm/390.html
For some reason, though, the resolution isn't going past 640x480. Also, it's not even scaling up to the size of the screen. I have a small box in the middle of the display that is being used, and large black bars around it. This remains the case even when using bios, and it was a problem before I even put an OS on.
First, I tried switching to a newer operating system. I loaded Windows XP 32x on it, but it got stuck on the "setup is starting windows" part during the installation. It hung on this for about 15 minutes before the screen went black. Then, I tried windows 2000. The same error happened. after checking my system requirements, I got to the "setup is starting windows 2000" screen, and it stopped.
So, I downloaded the BIOS System Program Diskette and upgraded my BIOS, but that didn't fix it.
I have what seems to be the correct driver, but i could be incorrect. On the display settings on win98, the driver title has my correct resolution, but I'm not able to move the slider past 640x480.
Anyone know what might be causing this? My thoughts are possibly leaky capacitors?
I can provide pictures if anyone needs.
Reply 1 of 5, by keeno
Here are photos if anyone needs:
Reply 2 of 5, by rasz_pl
lcd panel scaling should be switchable in bios in ThinkPad 390, maybe even a keyboard shortcut
https://github.com/raszpl/440BX Reference Design adapted to Kicad
Reply 3 of 5, by keeno
rasz_pl wrote on 2023-09-11, 21:59:
I've searched all over the bios but I can't find anything
Reply 4 of 5, by Thermalwrong
In your display settings picture it says it's a standard PCI graphics adapter (VGA) meaning it's running in basic VGA mode with a generic driver. You're looking in the right place for the driver software, so it's odd it's not working. In Win98 go into System > Device Manager to see if maybe there's an exclamation mark or if it's really just running the standard VGA driver.
I notice that your screenshot of the display settings shows the IBM specific monitor file has been loaded, but have you downloaded/installed the video features driver? That's the one for the video card: https://thinkpads.com/support/Thinkpad-Driver … es/vftpil9x.exe
For display expansion, looks like you need to go into the BIOS > advanced setup and enable "HV Expansion" under the others section: https://www.manualslib.com/manual/281753/Ibm- … ?page=36#manual That's also got keyboard shortcuts listed a few pages back, but oddly nothing for scaling. Scaling isn't very good with neomagic graphics btw, but it's fine for DOS games imo at 320x200 resolution.
Looks like you've already got the latest BIOS so win2k/xp should work. Since the laptop is getting this far in booting and running an OS, it's very likely fully working so don't worry about the capacitors yet.
Reply 5 of 5, by keeno
Thermalwrong wrote on 2023-09-11, 23:55:
In your display settings picture it says it's a standard PCI graphics adapter (VGA) meaning it's running in basic VGA mode with […]
Thank you so much, I installed the correct video drivers and it fixed the issue, and then I upgraded to Windows 2k and the problem is still fixed. I really appreciate it.
It seemed the issue with installing win2k and xp was that the BIOS was out of date.
