First post, by Yoghoo
I thought it was an easy task to choose a video card for my 1 Ghz Pentium III Windows 98SE pc. But I found the 3DMark results a bit inconclusive:
ATI Radeon 9600 XT
99:6370
01:5520
NVIDIA GeForce 2 GTS
99:6587
01:3028
The older GTS is unexpectedly a bit faster with 3DMark 99. And as expected the XT is faster in 3DMark 01. So which of the above cards would you choose for a 1 Ghz Pentium III? I got faster (and slower) pc's so performance is not the most important factor but what about for example compatibility. Is one of the cards a better choice for later DOS games and (more importantly) Windows 98 games until around 2000 because of drivers or features?
Reply 1 of 8, by shevalier
These are cards from very different times, although only 3 years have passed.
They focus on different directX.
The 9600XT sometimes outperformed the FX5950 in DX9 tests and was a direct competitor to the 5700 (ultra).
For Windows 9x and dx7-8, GF 2-3-4 and Radeon 7500/8500/9200 look more organic.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 2 of 8, by RaverX
I agree with shevalier, I'd also go with GF2 GTS, it's a perfect match for PIII 1000, period correct, also a high end card.
9600XT would be more suitable for a mid range computer with Windows XP, paired maybe with an Athlon XP.
PIII 1000 + 9600XT is a weird choice.
Reply 3 of 8, by The Serpent Rider
GeForce 2 GTS:
Pros:
- Table fog and paletted textures support (good for old D3D games)
- Less driver overhead with early drivers
- OMG it's Nvidia, you absolutely can't go wrong with GeForce!
Cons:
- Crappy 16-bit dithering
- Performance is dramatically worse with 32-bit color, not suitable for high resolution modes
- S3TC texture bug
- Image quality is worse
- Can't properly emulate all 3dfx Glide features (no shaders)
Radeon 9600XT
Pros:
- Decent 16-bit dithering
- Superior image quality
- Mostly accurate and feature complete 3dfx Glide emulation with Shader Model 2.0 support
- Much faster for high resolution modes, especially with 32-bit color
- TruForm feature support with early drivers
Cons:
- Driver overhead
- Only table fog is supported, with not paletted textures, so overall less compatible with early Direct3D games
- Not compatible with Intel 440BX chipset
Reply 4 of 8, by Joseph_Joestar
The Serpent Rider wrote on 2023-09-20, 08:53:
To clarify this, table fog is only fully supported on Radeon cards under WinXP, when using Catalyst 7.11 drivers or newer. Under Win9x, you can enable unofficial table fog support via registry tweaks. However, the fog will not look the same as on Nvidia/3DFX/Matrox cards, and it still won't work with certain games (e.g. Shadows of the Empire).
On the plus side, the 9600XT supports EMBM while the GeForce 2 doesn't. Image quality (sharpness) is much better on Radeon cards as well. Lastly, the 9600XT allows you to crank up Anisotropic Filtering to 16x, with minimal impact on the frame rate in most games.
My retro builds
Reply 5 of 8, by The Serpent Rider
By image quality, I meant horrible blocky texture filtering, which plagues all Nvidia cards of that period. GeForce 2 GTS had options with DVI ports.
Now for DOS, Nvidia card is much more straightforward choice, because it has VBE 3.0 support.
Reply 6 of 8, by Yoghoo
Thanks all! Very useful information. Will go with the NVIDIA GeForce 2 GTS for now.
Reply 7 of 8, by Pluming
GeForce 2 GTS: […]
GeForce 2 GTS:
Pros:
Cons:
- S3TC texture bug
Radeon 9600XT
Pros:
Cons:
- Driver overhead
Hi Serpent,
Long-time lurker, just wanna say that I appreciate your contributions to this forum.
That said, I do have a question. In terms of Windows 98, is there an Nvidia or ATI GPU that achieves the trifecta? Full support for 16-bit dithering, table fog, and paletted textures?
Thanks.
Reply 8 of 8, by The Serpent Rider
Nvidia has identical dithering pattern from Riva 128 up to GeForce 7000 series. It's not a significant issue, depending on who you ask and there are objectively much worse implementations out there (like SIS GPUs).
