First post, by wbahnassi
Hi guys, I have this 386 SX 16MHz Philips motherboard:
https://theretroweb.com/motherboards/s/philip … -5107-200-30042
It has no chassis connectors whatsoever. And I want to expose some LEDs out of it. Power and HDD are easy. The mobo can do Turbo switching (16MHz vs 8MHz) either via BIOS Setup, or via key-combinations during any time of operation, or even a SPEED.COM program that comes on the setup disk.
I wonder if it's possible to find a line on the mobo that can be used to tell whether Turbo mode is active or not. I can see three crystals on the board: 32MHz, 16MHz and a 9.6MHz. Wondering if those are selectively used between Turbo and non-turbo.
Any ideas or guidance on what to look for or where to trace from?
Cheers!
Turbo XT 12MHz, 8-bit VGA, Dual 360K drives
Intel 386 DX-33, Speedstar 24X, SB 1.5, 1x CD
Intel 486 DX2-66, CL5428 VLB, SBPro 2, 2x CD
Intel Pentium 90, Matrox Millenium 2, SB16, 4x CD
HP Z400, Xeon 3.46GHz, YMF-744, Voodoo3, RTX2080Ti
