First post, by Kordanor
I am thinking about upgrading my CPU to a K6 3 or a K6 2+ /3+
However I don't want to lose the ability to significantly underclock the CPU.
With my current K6 2-500, the lowest Clockspeed I can get is 167Mhz (2,5*66Mhz)
I found various pages about the K6 CPUs but none of them clearly states which FSB they run at as minimum.
For example: https://en.wikipedia.org/wiki/AMD_K6-III
They List 66Mhz as minimum for the K6 III models,
but for K 6 II+ and K6 III+ they only list 95, 97, 100 MHz and 95,100Mhz
Phil used the AMD K6 III+ ATZ 400Mhz at 1.6v at 66Mhz.
According to the Wiki thats not possible.
So something is off here. Is it generally possible to use all on them on 66Mhz? Do you need specific models like that 1.6v version? Or is there anything else I missed?
Reply 1 of 11, by paradigital
Underclocking is far more likely to be an issue for the board than the CPU. So long as the board has dividers for the PCI/AGP/ISA busses to keep them close to spec when at 66MHz FSB, the CPU shouldn’t care.
My DFI board could in theory run a 60MHz bus.
Reply 2 of 11, by Kordanor
So you think if the 500Mhz CPU can run on 66Mhz then there shouldnt be any issue with any of these other CPUs even though its not listed in their specs (on wiki)? But why is it then listed there in the first place... or is it just a manufacturer thing, saying that "they are inteded for 100Mhz" or something like that?
Reply 3 of 11, by Gmlb256
AMD K6-III and K6plus CPU runs fine at 66 MHz FSB as long as it POST correctly and have the necessary core voltage options.
On K6plus CPUs, the multiplier can be changed on the fly thru SetMul ranging from 2.0x to 6.0x, with the exception of 2.5x.
Reply 4 of 11, by Kordanor
Alright, thank you! Interesting case with 2.5x though. Guess its due to only having 1.0 increments?
Reply 5 of 11, by aitotat
I tested K6-3+ (modded K6-2+) with 50 MHz bus (and much more) some time ago. I didn't notice any issues with 50 MHz but it was not useful. Here are the results.
Reply 6 of 11, by analog_programmer
Kordanor wrote on 2023-09-26, 14:32:
Wow, really? And what tells about this matter the universal knowledge of g00gl? 😁 😁 😁
Seriously, wikip...a is full of bu...hit. I've successfully tested mine K6-2+/500 down to 200 MHz (3 x 66 MHz FSB) on PCChips socket 7 mobo (I do not have any ss7 board) and the CPU worked just fine.
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 7 of 11, by Kordanor
Google told me even less. Most pages only list 100 Mhz 😁
If I didnt see the Video from Phil I would not have known in the first place 😁
But its great to know, thanks a lot!
Reply 8 of 11, by Gmlb256
Kordanor wrote on 2023-09-26, 15:01:
The increments are 0.5x and being unable to set 2.5x thru software is just a limitation of the K6plus microarchitecture.
analog_programmer wrote on 2023-09-26, 16:30:
That Wikipedia article was written by clueless people who didn't do some actual research and followed the things "by the book". 🤣
Reply 9 of 11, by analog_programmer
Kordanor wrote on 2023-09-26, 16:43:
I'm assuming it will run fine at 2 x 50 MHz FSB, I just haven't bothered to test it lower than 200 MHz.
Reply 10 of 11, by gerwin
analog_programmer wrote on 2023-09-26, 17:02:
There is SpeedSys screenshot of a K6-2+ running at 2x60MHz here, on page 1:
SetMul - Multiplier control for VIA C3 / AMD K6+7+8 Mobile / Cyrix 5x86
I do not have a motherboard with 50MHz FSB option to try. But 60MHz FSB is never a problem with any Socket 7 CPU.
Reply 11 of 11, by Kordanor
Cool, thanks. Yeah, no need for 50Mhz anyways. If I can do 66Mhz that would be good enough (at 2x or 2.5x)
