First post, by Lodge_
I've had the ASUS VX97 v1.01 motherboard paired with Pentium MMX 233 and the latest MR BIOS (from 1999) for a while now. I'm quite satisfied with it, but a few games from 1998 seem a bit sluggish at times so it got me thinking of upgrading the CPU if that would make a difference.
Does anyone have first hand experience of using AMD K6-2 processors with this motherboard? The settings for the 2.2V voltage aren't documented.
The multiplier setting are 66 Mhz bus x6 (jumper set at 2x because the K6-2 processors treat a 2x multiplier setting as 6x). Am I right?
But what about the voltage?
I found this old newsgroup post below from the year 2000 with the exact same issue!
I thought that the solution for 2.2V should be as simple as VID1 1-2 closed? But then I compared the settings for 2.5V and 3.2V. 2.5V is the same as below but has extra jumper over VID1 2- 3. 3.2V is totally diffent so I'm not sure anymore?
>> I just solved the problem!!!! VX-97 and >>TX97 and TX97-e (someone confirm the tx's as >> I only have a vx97) supports all >> […]
>>voltages 2.0 - 3.5 in 0.1 volt increments. The may
>> include any Asus board with an HIP6008
>>voltage regulator.
>> The vid block connected to HIP6008
>>regulator looks like:
>> vid2 3 x 2
>> vid1 x x 1
>> vid0 x x 0
>> And the voltages:
>> 2.0 No jumpers
>> 2.1 vid0 1-2 (no other jumpers needed)
>> 2.2 vid1 1-2
>> 2.3 vid0 1-2, vid1 1-2
>> 2.4 vid2 1-2
>> 2.5 vid0 1-2, vid2 1-2
>> 2.6 vid1 1-2, vid2 1-2
>> 2.7 vid0 1-2, vid1 1-2, vid2 1-2
>> 2.8 short the 3 to vid1:3 (ie: vid2:3 to
>>vid1:3)
>> 2.9 short 3 (see 2.😎, vid0 1-2
>> 3.0 short 3, vid1 1-2
>> 3.1 short 3, vid0 1-2, vid1 1-2
>> 3.2 short 3, vid2 1-2
>> 3.3 short 3, vid0 1-2, vid2 1-2
>> 3.4 short 3, vid1 1-2, vid2 1-2
>> 3.5 short 3, vid1 1-2, vid2 1-2, vid3
>>1-2
>> Specs on the HIP6008 found at
>>www.intersil.com.
>> Enjoy! The world of vx97 overclocking is
>>open to the k6-2's now! Notice that Steve's
>> solution below for 2.5V included a
>>jumper on vid1 2- 3. It is optional equipment.
The was a similar thread about using the VX97 and the K-2+ (2.0V) processors, but that had to be about the rev 1.02. Rev 1.01 only supports 66 Mhz bus. Here:
K6-2+ 450, Asus VX97 Build - updated now to include some 430TX vs. 430VX benchmarks
You can find the datasheet for the voltage regulator here:
https://www.digchip.com/datasheets/parts/data … P6008CB-pdf.php
Reply 1 of 1, by Repo Man11
I think quicknick's post here has the method you need to verify the core voltage setting: Re: Checking voltage on socket 7
If you can verify that it goes as low as 2.2 volts, you'll also be fine with a K6-2+ (yes it's overvolted, yes this isn't ideal, but a decent CPU cooler and it will be good for years). If you can set it to 2.0 you'll really be set. The Retro Web mentions that motherboard is known for having power delivery issues, hopefully yours does not. They also list a patched BIOS by Jan Steunebrink (our Socket 7 savior) with K6-2+/3+ support, and large hard drive support.
https://theretroweb.com/motherboards/s/asus-vx97
I just did some benchmarking with a VX chipset motherboard and a K6-3 and a K6-3+. It's a PCChips board so it almost certainly isn't as good as your Asus; it's likely that with the same CPU your board will have slightly better performance. A significant advantage of the plus series CPUs is that the multiplier can be changed by software to slow it down for speed sensitive games, while a standard K6-2 or K6-3 can only be slowed by disabling the cache and/or changing the jumper settings.
Re: Working K6-2+ doesn't work for me.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
