First post, by ncmark
I just wondered if someone could shed some light on this.
I have a sandisk extreme, formatted NTFS. From windows 7, if II run check disk by itself, no problem. If I run it with "automatically fix file system errors" checked then it hangs past a certain point.
My first thought was, it got corrupted. So reformatted, with NO FILES on it, same behavior.
On a different computer, same behavior.
If I reformat it exfat, then no problem.
I recently got a samsung shield t7. Brand new, out of the box, same behavior.
I am rather puzzled.
Everything I have read said NTFS should not be a problem on an external SSD. I am at a loss. Perhaps the solution is simply to use exfat (which is what I did on the T7)
I thought about a virus, but according to every test I can run there is none.
