First post, by Panties
- Member
Hi Gurus,
I've been doing a lot of research, and I can't seems to find USB 1.1 port for PCI slot.
I Need help on my PM-8600 motherboard. (sorry If I sound noob)
My motherboard, according to the manual, have 10 PIN.
https://theretroweb.com/motherboard/manual/86 … 49731374762.pdf
Also, when I open up my casing, it has 10 PIN on it.
https://theretroweb.com/motherboards/s/amptro … 8600a#downloads <--See picture of motherboard.
I'm trying to find "2-Port USB 1.1 PCI Rear Panel Expansion Bracket to 10pin Header" in shopee or ebay,
but my results are mostly "2-Port USB 2.0 PCI Rear Panel Expansion Bracket to 9pin Header" .
(https://shopee.com.my/2-Port-USB-2.0-PCI-Rear … e7-73ca46685464)
Where can I find Dual USB 1.1 port PCI bracket Slot, for 10 PIN header?
Do I have to get a converter from USB 2.0 to USB 1.1, so that I can plug into the motherboard?
& Does USB 1.1 have 10 PIN compare with USB2.0 9 PIN?
Thank you in advance...
