Problem with Stonekeep
First post, by George_73
When i install the game through DoSbox it freezees in a state called "verifyibg game data please wait". I simply bypass this stage by closing and restarting DOSbox but when i try to run the setup.exe in the newly installed directory it displays me the message "Error: HMI drivers not present in this directory" What can i do? any ideas?
Reply 1 of 8, by eL_PuSHeR
Obviously you cancelled the installation procedure (and not all files were copied). Did you try installing it using VDMSound?
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 2 of 8, by George_73
Thank you for your precious info
Reply 3 of 8, by eL_PuSHeR
Save the sarcasm. Did you get your problem fixed?
Intel i7 5960X
8 GB DDR4 (2100)
Reply 4 of 8, by George_73
Actually no. That's the reason i came back, but still thank you for your interest and your time. Any other ideas?
Reply 5 of 8, by eL_PuSHeR
Yes. If you haven't done so already, take a little of your time SEARCHING the forum. Stonekeep has been discussed several times and I positively know that it works for some people (including me. I played it some time ago using WinXP).
Intel i7 5960X
8 GB DDR4 (2100)
Reply 6 of 8, by Robert de Clair
A solve ist waiting 😀 I have same problem with ORIGINAL stonekeep installer. You must wait about 3-5 minut's just surf the web or something 😁 after that just appearing sound card configuration. Configure Your card and enjoy
http://www.krokmania.com
DDR and Stepmania site
Bądź sobą, nikt inny tego za ciebie nie zrobi.
Reply 7 of 8, by eL_PuSHeR
You both should try some recent CVS version. Search the forum for info.
Intel i7 5960X
8 GB DDR4 (2100)
Reply 8 of 8, by Killer Koala
I had the same problem, I thought it had crashed at verifying but I waited a few minutes and it finished up no problem.
