First post, by Blitz_25
Hi,
Anyone knows v75m motherboard usb hub pinout? I cant find any reference on the net. Sofar i fried 2 usb memory sticks when coneting them to frontpanel usb port. Front panel is connected to usb hub pins in following way (regular usb pinout) :
pin 1/2 5v (red)
pin 3/4 - data (white)
pin 5/6 +data (green)
Pin 7/8 is not present
pin 9/10 gnd (black)
Doas v75m use any special usb pinout layout?
Rearpanel usb ports work ok.
Reply 1 of 6, by Repo Man11
This illustration shows what appears to be the standard nine pin USB motherboard header, but the photo on The Retro Web shows a non standard pinout. With a non standard pinout meant for a proprietary connector and no documentation, I would verify the pins with a meter.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 2 of 6, by Blitz_25
Indeed it looks like propietary pinout as the pins 7 and 8 are not present and not the standard 8/9 pins usb connection found on most motherboards.
I will check the pins vith multimeter. Is there anything i hav to watch out for so i do not fry something while mesouring live usb contacts?
Also when i want rear usb to work pins 1&2 as well as 3&4 on USB hub need to be shortened (defoult state) if they are opened rear usb doas not work🤔
Reply 3 of 6, by Repo Man11
When measuring the USB pins you do need to be careful to have a steady hand and good light on what you're working on as a slip could lead to grounding the +5 pin, and that could cause damage.
Others may weigh in on this, but it sounds to me as though you'll likely be stuck using either the front or rear ports. A USB card with headers for front USB ports is a solution, but even the best of those will cause a measurable performance hit on Socket 7 systems. Sphere478 decided that he was tired of having too few USB ports so he did this: Re: Adding more usb ports to old motherboards without using a card
Reply 4 of 6, by Blitz_25
I took a look with multy and found that what i thaiugt was ground acctually was 5v power line. I'm stuck now o. How to determine what pin the ground is. Any way to find this?
Reply 5 of 6, by Repo Man11
Though non standard, it should still be a variation on one of these pinouts. To check for the ground pin you should be able to set the meter to check for resistance and put the ground probe on the case, or one of the motherboard's mounting screws. https://web.archive.org/web/20050830011044/ht … le_assembly.htm
Reply 6 of 6, by Blitz_25
I checked USB HUB with multimeter and the pins are in non standard USB layout as follows:
pin 1/2 - data (white)
pin 3/4 +data (green)
pin 5/6 gnd (black)
pin 9/10 5v (red)
hence why it killed 2 of my USB sticks. It still puzzles me why if i want rear usb to work pins 1&2 (-data) as well as 3&4 (+ data) on USB hub need to be shortened (defoult state). If they are opened or if i connect fron USB the rear usb doas not work so i can either have front working USB ports or rear working but not both together.
