First post, by Rav
Here is the first version of an universal chipset configuration for, initially, 386 and 486 systems.
Current version : 1.1.2 (Final release of 1.x real mode branch) ->
The attachment ucp112.zip is no longer available
Retested with 86box with emulated ALI 1429 and ALI 1489 (My Ali1429 486 is out of service right now)
Source as promised as I won't work on this branch anymore (except if there is real interest for it) :
The attachment ucp-src.zip is no longer available
To be compiled with Borland C++ IDE
Functions:
Permit changing the different chipset registers to allow proper configuration for when the BIOS is limited. Or to do testing instead of to prevent needing to reboot many time.
It also allow to change the cache mode between Write-Back and Write-Through.
Currently implemented:
  • ALI 1429/G (If you have an Acer with some A1G/A1GX motherboard, it's the program you need to make it from meh to actually good)
  • ALI 1489 / FINALi
Implemented features
  • Display chipset parameters
  • Change chipset parameters
  • Display parameters valid only for selected chipset
  • Perform memory test for every memory configuration change (with /test parameter). Automatically rollback in case of a failure
  • Change cache mode
Generic parameters
  • /test -> Will execute memory test after important memory timing change. Soon will also do the same for cache
  • /list -> Display configured parameter. Can be used while setting parameter then in that case, it will display all current configured parameter once it is done configuring them
  • /cs -> Specify cache size in KB. Normally it will detect the cache but in case it miss-detect or if you want a slightly faster execution, say, if you put it in the autoexec.bat, you can specify it there
  • /v -> Verbose mode, only used for cache configuration or memory test
  • /chip list -> show list of supported chips
  • /chip chipname -> select a chip
Base parameter and /list usage:
The attachment ucp1.jpeg is no longer available
Selected chip help plus actually configured parameters:
The attachment ucp2.jpeg is no longer available
Demonstration of applying parameters then displaying the list of configured settings with /list
The attachment ucp3.jpeg is no longer available
Upcoming feature:
  • More supported chipset
  • Bruteforce mode
  • Perform cache test for every cache configuration change (with /test parameter)
  • Ability to do a memtest or cache test without changing any parameters
Current limitations:
  • Patching cache mode [WT/WB] on Windows (it can work... some rare time by luck, but it usually endup with a system crash. There is no problem about changing the other registers on Windows, but know that changing them will be more sensitive)
  • Patching cache mode [WT/WB] when himem.sys memory manager is used and there is actually more than ~32MB of used memory (say, you have xhdd /S32 in the config.sys, then it crash every single time I tested). Work fine with QEMM.
  • Cache detection work fine in real mode and protected mode but if you use the tool in protected mode while the whole kitchen sink is loaded, miss detection may occure
  • Cache detection on Windows, don't expect that to work reliably
  • Running the tool from a etherdfs network drive will result into a crash (real mode) or a memory protection error (protected mode). Netware drives are fine, did not test with LANMAN.
Special thanks to : mkarcher, feipoa
I will also need chipset register dumps from you guys, I will also update my dumping too to be more complete and release it. That should help me for the "chipset detection" update.
I will add a credit switch in the program, and list all the peoples who help.
Reply 1 of 25, by jakethompson1
It's a nice idea, but: 1. What about CTCHIP?, and 2. in an application of Murphy's Law, the chipsets with the least capable BIOSes (making it hard to reverse them to determine a register map) also are the ones with elusive datasheets.
Also, you might get mired in chipset revisions. For example, I was curious about changing the cache line size on a 386-based UM480 board, but MR BIOS displays the cache line size and won't let me change it (making me think the capability is revision-specific) and when I write my own program to do it (including cache flush et al), the system locks up.
Reply 2 of 25, by Rav
jakethompson1 wrote on 2023-10-10, 01:05:
CTCHIP is great.
But:
* try to change cache mode (specially WB->WT) without crashing
* It does not test the settings after applying them, with is what a plan to do with 1.1.
* Can you get cfg file included in a new release? oh wait, last one is from 1999 😒 So you have to hunt them with no hope of getting them added in an official way.
Personally I did use ctchip34 a little, but that was after I made my own .asm tool. Then I made a ctchip34 cfg file for my chipset... And used it mostly for debugging purpose 😉
That is why I want to detect chipset if possible, and not propose options that won't work on X or Y
As you said, you need to program something to flush the cache, because ctchip can't do it....
I don't think I can support all chipsets.
Reply 3 of 25, by mkarcher
Rav wrote on 2023-10-10, 01:13:
Actually, ctchipz can do it. Some cfg files contain "macros" that perform different operations in sequence. Flushing / reloading the cache is available in macros. There is a bug in the reload code if you try to reload more than 512K. This needs to happen in protected mode and this code path reloads an insufficient amount of data, IIRC it reloads 1KB/2KB instead of 1MB/2MB. This only gets relevant if you have 512K of cache or more.
I have a patched version of ctchipz somewhere that fixes the bug concerning big reloads. If there is interest, I might dig for it and post how to fix that bug. On the other hand, a legal open-source chipset adjustment program would be great, too.
Reply 4 of 25, by Rav
mkarcher wrote on 2023-10-10, 06:56:
That's good to know
I do plan to release the source once I reach 2.0 (once the program is feature complete for what my current plan is). Initial post updated.
Reply 5 of 25, by Rav
Next millstone coming soon!
Memory tester working (pattern in screenshot, if you guys have recommendation for better patterns, let me know)
Now that it work, I have to update the code so "/test" will just execute the test after every memory/cache register change.... instead of just do a memory test alone
The function already return 1 if it fail, and 0 if it success, so with that I can just revert to old timing if it fail.
On DOS, all available XMS is tested
On Windows 3.1, 16MB worth of XMS is tested.
if the memory is fragmented, it still allocate all the available blocks to test them so it work fine if the available XMS is not contiguous.
The attachment soon_v1.1.jpeg is no longer available
Reply 6 of 25, by Rav
So automatic test for critical timing when /test parameter is set, is working, including setting rollback.
Have to polish it a little (maybe replace all that verbose stuff by just replacing the "OK" on the right for "TESTING[pattern]", then change for OK if OK or failed if Failed.
Then add an extra "revert the setting" line when there is a fail.
Will be more easier to read when user change many settings in the same time...
The attachment soon.jpeg is no longer available
Reply 7 of 25, by Rav
Added millstone:
{1.11->1.12}
-> 1.11 : Display currently configured things in the same page as the option list (when you just type ucp without parameters)
-> 1.13 : Bruteforce settings : /bruteforce, will set and test memory and cache related timing and find best "stable" timing for you, including listing all the parameters at the end, if you wish to just stuff them in the autoexec.bat or do some test later. That probably won't replace real applications / stress testing but that could give a fast start with optimum settings. ( And if detected, will also set Cyrix 5x86 CPU to max feipoa recommended "optimal", The one without BTB" settings. Other CPU I don't know yet as I don't have what available for properly testing. - yet -)
Reply 8 of 25, by Rav
New version have been released
Two new versions have been released
First post updated for new version
Changelog 1.1.1
  • Fixed *char length for the chipset text data... 1489 have longer string that I initially planned
Changelog 1.1
  • Added support for ALI 1489 / FINALi
  • Added support to list all parameters /list
  • Refactored the code so it can support many chipset
  • While it display the selected chipset available configuration parameters, it now use color to show what are the currently configured settings
  • Added L2 cache detection. It is used when cache mode is changed, instead of a fixed value
  • Added cache size override option /cs
  • Memory test and cache change mode are not verbose anymore, only with /v
Reply 9 of 25, by Pr1ha
Rav wrote on 2024-02-13, 18:13:
New version have been released Two new versions have been released First post updated for new version […]
Changelog 1.1.1
Changelog 1.1
Hello, when can I expect new versions to be released? Or has development been suspended?
Reply 10 of 25, by Rav
Pr1ha wrote on 2025-07-15, 18:56:
Changelog 1.1.1
Changelog 1.1
Hi, I did not work on it lately as I made an option rom that fix my issues and adjust all the thing for my 486 before it leave the BIOS and so I did not use the tool myself since that.
I was actually considering just releasing the source very soon. I have only a 486 with an ALI1429G chipset so I can't test with others.
Reply 11 of 25, by Pr1ha
Rav wrote on 2025-07-15, 19:29:
If this rom is for the 486 ALI M1429, could you post it here? I am solving the same problem.
Reply 12 of 25, by Rav
Pr1ha wrote on 2025-07-16, 09:31:
Sure, note that it's personalised for my specific system so you will need to change settings.
Here the rom code :
The attachment ali1429.tar.bz2 is no longer available
, you are going to need to edit it according to what work for you (You can use the UCP tool I made to test what work best and then just edit the rom with that and compile it with FASM. Other than the option you want to adjust, you might want to edit what's on top of the main.asm file (ROM_SIZE_IN_KILOBYTES) if your is a different size from 8KB.
What you want to edit : The size of the rom parameter at the top. And all the setting it set according to what work for you in UCP. ALSO the rom take in account that the BIOS set the L2 cache strategy to Write-Back And assume that you have 256KB of it. If you have more than 32MB worth of RAM, it will automatically change the strategy to Write-Thru (The line that have a progress bar in the screenshot. The ram detection routine is after the patchTheCache: label in main.asm and the comparison for 32MB is line 260. If you have a different amount of cache you will want to update that. Here in the code it is 0x7C (for 256KB of L2), if you have 512KB you want to replace that for FC.
If your bios boot with WT instead of WB and you want to automatically switch to WB during boot, replace line 262 "jle" for a "jg" and in line 272, you replace the 0x00 for 0x08 and also in strings.asm, replace the "Switching cache to Write-Thru" for "Switching cache to Write-Back".
Finally if you look at the screenshot, in the botton you have a few hotkeys, they are CYRIX specific. During boot the rom will detect if you have a Cyrix 5x86 and if so will use feipoa optimal safe settings, and will allow you to enable or disable BTB flag on the fly (it also disable other stuff that cause the system to crash if BTB is on). It also have a hotkey to enable 0WS for cache read, also on the fly. These hotkey won't be proposed and won't work if you do not have a 5x86 but you might want to modify the code to bring the 0WS toggle back or change it for some other settings you want to be able to change on the fly later, with hotkey. Note that the last line about pressing F1, is also 5x86 specific not implemented.
Also, if you have a cyrix 5x86, check that Interrupt 0x49 and 0x4B are available. 0x49 is used to backup 0x09 for keyboard hook, 0x4b is used for the non existent menu I planed to make but never made... yet (you can strip that part out)
The attachment 2025-07-16_14-05.png is no longer available
Reply 13 of 25, by Pr1ha
Thanks, I'll try.
Reply 14 of 25, by Pr1ha
Rav wrote on 2025-07-16, 20:12:
Please help me.
The BIOS on my Acer A1G motherboard is too old, and I can't install Cyrix 5x86 in L1WB mode. Could you share a BIOS dump of your motherboard?
All newer versions older than 1994 have been lost online.
Reply 15 of 25, by Rav
Pr1ha wrote on 2025-10-12, 08:21:
Please help me. The BIOS on my Acer A1G motherboard is too old, and I can't install Cyrix 5x86 in L1WB mode. Could you share a […]
Please help me.
There you go
The attachment Acer.bin.zip is no longer available
Please note that this BIOS include the system ROM and the Video card ROM. You might have to swap the Video card rom part if you are using a different integrated card than mine (GD-5430)... If your using a discreet card, then I don't know.
Reply 16 of 25, by Pr1ha
Thanks
Reply 17 of 25, by Rav
New version coming soon
* PCI support (autodetect)
* save config
* If no PCI then ask use to choose his ISA chipset (will remember chipset and settings)
Of course it have /autoload switch so one can put it in the autoexec.bat
The attachment 1.jpeg is no longer available
The attachment 2.jpeg is no longer available
The attachment 3.jpeg is no longer available
The attachment 4.jpeg is no longer available
Reply 18 of 25, by MarmotaArmy
Thanks , I just got an Acer with the A1gX motherboard and a 486 SX2 50 and this will come very handy
Reply 19 of 25, by aVd
Hi, @Rav,
I just found, that I have a motherboard with ALi M1489/87 (FinALi-486) chipset - DataExpert EXP8449 rev. 1.2. What can I do with your Universal Chipset Patcher?
Thank you!
what comes around goes around
