First post, by Tomek TRV
Hello
I am trying to fix few 386 motherboards eaten by battery acid. I also need to add some parts which were taken somewhere in the past by previous owner. One of these parts are chips like n title of this post. I can't find datasheet for ICW chip and I would like to know can I use AV9107-05 instead of ICW42C07.
Reply 1 of 2, by snufkin
Is this it: https://www.datasheetarchive.com/datasheet?id … pe=O&term=42c07
Looks very similar to this: https://www.datasheetarchive.com/datasheet?id … &term=av9107-05
But Ive only skimmed both sheets.
[edit: in fact the ICW sheet lists uses the av9107-05 as a cross-reference part, so it should be a drop in replacement]
Reply 2 of 2, by Tomek TRV
Thank You. I couldn't find this datasheet but it really look's like I can use these two chips as a replacement. I will try this for sure.
