First post, by 7crimson
Hello!
I apologize beforehand for the topic does not relate to dgvoodoo directrly, but i just dont know whom to ask anymore. I am trying to modify ZanZarah: The Hidden Portal game, specifically the .scn files. I googled for editors and there are such stuff on GitHub(i.e. https://github.com/Helco/zzio), BUT it needs to be compiled - which i tried and failed. My PC is also slow so downloading full visual studio IS a problem. I googled that ZanZarah was written on rendeware engine, and it even has a studio - so i downloaded that but it doesnt load .scn files too. Seeing as zanzarah cant work on modern pc without DgVoodoo perhaps you know of some ways or tools to mod the game?
Reply 1 of 5, by zyga64
You don't have to compile. Just go to: https://github.com/Helco/zzio/releases
Click on Assets to expand it, and download zzre-win-x64.zip
Scamp: 286@20 /4M /CL-GD5422 /CMI8330
Aries: 486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
Triton: K6-2@400 /64M /MGA-2064W+3dfx /YMF718
Seattle: P!!!750 /256M /MX440 /Vibra16s+SBLive!
Panther Point: 3470s /8G /GTX750Ti /HDA
Reply 2 of 5, by 7crimson
Thank You!
But unfortunately the realese version i downloaded does not contain sceneeditor. while the source code has the designated folder for that tool. Unless i dont understand something.
Reply 4 of 5, by zyga64
BTW - you don't need Visual Studio for compile. Net core SDK is enough.
cite:
    Install a recent .NET 7 SDK
Run ./get-dependencies.sh in the root repository folder
Now you should be able to build zzio.sln using the dotnet CLI or your favorite IDE
So after installing SDK, you have to execute following (in console - either cmd or powershell)
1.) ./get-dependencies.sh
2.) dotnet build zzio.sln
Reply 5 of 5, by 7crimson
okay so:
1 the version i Downloaded from Assets DOES have a scene editor/viewer, but there is no way to save the changes .(rofl!!!)
2 i have installed net 7 sdk and ran get-dependencies.sh in cmd but it uses old net.framework 3.5 code (dont know how to turn it off/change it) - all i get is a load of errors.
