The Serpent Rider wrote on 2023-10-18, 22:22:
These chips practically have identical price now, because very small amount of people cares about performance of 15+ year garbage can CPUs.
Umm... in my (admittedly-limited-but-still) experience, the top of the line of any particular CPU generation tends to sell for a lot more than any of the other chips from that generation. Which makes sense because people who got the slowest of a generation may, 5-7 years later, go looking for a cheap upgrade and obviously they'd want the top option that fits in their board. The E6700 is the flagship of the dual-core 1066MHz first-generation C2D platform... (and probably relatively rare, too, that was an expensive CPU back in the day and most people got the E6600 which humiliated AMD's entire lineup just as much...)
That being said, unless you have a motherboard/system you're attached to that's limited to 1066FSB or 65nm, there are certainly better C2D/C2Q options out there, e.g. the 45nm chips such like the E8600 or Q9650. Or, if you just want a later XP-era system, you can go to a sandy/ivy bridge.
But if you inherit a random system from late 2006, possibly even one that combined its P965 chipset with a HotBurst Pentium 4/D (I believe Dell, at least, sold some machines with both Pentium D and C2D options on the same board), why wouldn't you want to upgrade its CPU to the fastest that can go on that board, at least if it's half-reasonably priced?
(Also, I'm not sure what makes these CPUs so 'garbage can'. They're probably the first CPUs in history to not be completely obsolete 10-15 years later... honestly, if you're bored, stick 8-16 gigs of RAM on a C2D/C2Q board, plug in an el-cheapo SSD and install Windows 11 unsupportedly. It's... strangely usable. Would I trade in my modern systems for it? No... but if the modern systems had a motherboard failure and I had nothing else for a week or two, I could most definitely make do with a C2D/C2Q. They'd probably outperform some super-el-cheapo laptops on sale at Worst Buy today, or at least two years ago, too. Try doing that with any other 15 year old motherboard/CPU in history. )
