First post, by ludoretro
Hello Everyone,
I am sure some of you already went through this with your IBM 300PL Tower. This tower features an AGP port however I cannot seem to figure who to insert the video card (tried with TNT2 Ultra and a Quadro2 Pro)
Here is a picture of the case for the 300PL I have in my possession.
There is an older post of a build in Vogons where the person shares pictures of the inside of the case... however the pictures are not available anymore.
IBM PC-300PL - Diamond powered!
The post is very detailed though and mentions a double backplane to support the AGP card. It also references IBM manuals uploaded on the site and one of them shows how to install the AGP card and does not mention any riser... However I am not able to follow the instructions. The card metal plate ends on the motherboard so that's not good. I also removed the card plate but it still does not fit into the slot. The card would fit with the outputs facing the other side. Again it does not make sense to me.
http://www.vogonsdrivers.com/getfile.php?fileid=677
Any idea?
Thank you,
