First post, by Jo22
- l33t++
Hi everyone,
There's something that just crossed my mind while browsing through my small VHS collection.
Is there, by any chance, an equivalent to an electric audio cassette?
I mean these passive AF to cassette devices containing a recording tape head.
Video is understandable more complicated, also because it has higher bandwidth and uses helical recording. 🙁
Also, a physical tape or ribbon must be available of some sort, because the video head drum is deep inside the VCR, in stark contrast to the playback head of a cassette player.
But technically speaking, would it be possible to build something like this? And how?
In principle, I mean. I'm not going to attempt to make one.
I mean, in theory, there are two approaches that come to mind.
a) to install a miniature, record-only VCR inside the tape chassis. It writes the actual video on a physical endless tape (loop).
It's entirely analogue and fed by an external source over a flat cable (like the audio cassette equivalent).
Problem is the helical recording. How can this be done, considering the height limitations?
A normal helical drum wouldn't fit inside, sadly.
b) Use of an hypothetical electrical tape that's not moving. It has a fixed lenght and just covers the video head drum/playback head, like a real tape.
Not sure how this hypothetical tape may work, though.
Maybe like a long, flexible version of a VCR write head.
Maybe like an magnetic version of a CCD chip.
Or a ribbon with set of miniature coils that are individually controllable.
It doesn't need to be the whole size of the dummy video tape, I assume.
Just long enough to cover the video head drum/the playback head accordingly.
The low resolution nature of VHS would even suit the project, maybe.
That being said, this is just a thought experiment.
Any ideas or thoughts welcome. ^^
Best wishes,
Jo22
