First post, by VivienM
So... I received my Biostar K8M800 board yesterday, trying to set it up as a 98SE machine. 1GB of RAM, regrettably a 1x1GB DIMM. Using a 30 gig SATA SSD I've had for a long time and a SATA ODD; I'm regretting the SATA ODD but other than a 6X DVD-ROM pulled out of a Power Mac, I don't have any PATA ones and the local Free Geek doesn't have any either.
Trying to install 98SE. Have run into a bunch of problems, let's see:
1) The DOS driver on the bootable CD-ROM won't recognize the SATA ODD. Okay, easy enough to fix, just format the drive and copy to the SSD.
2) I've been installing the rlowe PATCHMEM and PTCHSATA, but... I can't seem to get past the Win98 install. Most of the time, it just locks up at the cloud splash screen. Occasionally I make it into the installer where it scans for devices, and it crashes there.
Once, I made it as far as the 'you don't have a PS/2 mouse plugged in' screen, but sadly, the only keyboard I had was USB and the USB emulation... so I wasn't able to go past that. When I dug up a PS/2 keyboard, well, it wouldn't boot.
Occasionally, I get protection errors. Now just got a new one, an exception 0C at 001D:0000FE84.
I've reinstalled Windows... 3 or 4 times. Hopefully deleting C:\WINDOWS is enough, I probably should reformat but that would require re-copying the installation files, the rloew patches, etc.
I've turned off the PATA channels in the BIOS, turned off AHCI, etc.
Board/video card seemed to work fineish with a random 2017 (i.e. way too new) bootable Linux disc I had around. I'm tempted to install XP or 7 and confirm a newer OS is happy with all the hardware before.
Any advice?
Oh, and one other weird thing - that motherboard loves the 1 gig of DDR2 the eBay seller sent with it, but hates my 2 Kingston DDR2-667 512 modules that have probably been sitting in around for over a decade. Is it possible for RAM to ... corrode, which would explain why it doesn't seem to want to fit nicely and even when it somewhat fits, it won't POST?
