First post, by Try_deleted
Hello, im using a system with the msi k8mm3-v motherboard and the AMD sempron 3000+ CPU. I want to dual boot Windows 2000 and XP, i have enough storage for it, i want the maximum performance from the pc and the Sempron 3000+ seems kind of slow. I cannot get my hands on another 98, 2000 or XP compatible PC as people are overpricing the parts where i live.
I have found an AMD athlon 64 3700 cpu online for 15 dollars, and i was wondering if its worth the upgrade? Thanks
Reply 1 of 2, by shevalier
Twice as fast and twice as hot. (89Watt TDP)
If you want pathos, you need to take it. For real use, the more recent Venice with a 65W TDP and made using a 90nm process is better.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 2 of 2, by BitWrangler
I'd grab it, anything over 3000ish seems very hard to find for reasonable money now.
