Hi, may I ask which network protocol are you using?
If NetBIOS and/or LAN Manager is involved, file and printersharing should work, I think.
Printing to a file makes things easier, too, I believe.
Speaking under correction, though.
I remember using WfW for Windows stuff and Novell, Kirschbaum software for DOS stuff.
I can't remember using DOS applications on Windows so much.
There was a Workgroup add-on, though which worked with DOS (and indirectly Windows 3.1).
Workgroup Add-On for MS-DOS, I believe.
This one should support MS-DOS applications, at the very least.
Hm. This HP site has LAN Manager drivers, it seems.
http://www.hpmuseum.net/display_item.php?sw=282
That being said, these are all products from the pre-TCP/IP days.
Back in the early-mid 90s, TCP/IP was barely established in normal LANs yet.
This changed with Windows 98, I think.
Windows 95 supported TCP/IP on paper, but was still heavy being involved in existing DOS/Windows 3.1 networks using IPX/SPX or LAN Manager.
But maybe that was just in my place, not sure anymore.
That being said, there are many other users here who're running vintage networks at home.
They surely know how to print from a DOS applications running on WfW.
