First post, by mtest001
Hello all,
I need some advice and help to increase the available disk space on my retrogaming PC.
The specs of my machine are as follows:
Mainboard: Shuttle HOT-569 Socket 7 (chipset 430TX, PCI 2.1)
CPU: Pentium MMX 200 @ 225 (3 x 75 MHz)
Memory: 128 MB SDRAM
HDD: IBM DCAA-34330 Deskstar 4 4.3 GB 5400 rpm
Soundblaster live with front 5.25" panel
Accton ISA network card (10 Mbps NE2000 compatible)
5.25 SAMSUNG CD-Master 52E
3.5" Floppy drive
AT keyboard
Serial 3 buttons Logitech mouse M-M35-9F
12 inches VGA screen from TATUNG
I am looking for convenient ways to increase the storage space on that machine. I bought a cheap $10 SATA->IDE adapter but unfortunately this does not work. When I connect a disk through that adapter the BIOS HDD automatic discovery process hangs and I need to reset the PC. I've tried with 2 different drives, 1 x 128 GB SSD and 1 x 160 GB HDD, as master or slave, and always get the same result.
Not sure from where the problem comes, I believe I have the latest BIOS available for my mainboard but I read that those adapters do not always work.
Now I am considering several alternatives:
a - Buy another, hopefully better quality adapter such as the DELOCK 61635 bi-directional adapter, but I fear I will have the exact same result,
b - Buy a CF->IDE adapter, solution which seems to be well supported but it's a higher investment (CF card are not cheap!),
c - Buy a SATA PCI card - I found a PROMISE SATA300 TX2plus but I am not sure if this card is well supported under Windows 98.
Please let me know your opinion.
Thanks a lot.
    512.71 KiB
    23.64 KiB
/me love my P200MMX@225 Mhz + Voodoo Banshee + SB Live! + Sound Canvas SC-55ST = unlimited joy !
Reply 1 of 44, by konc
d - Discover the max HDD size that your BIOS can handle and try something smaller, or you won't be able to know if the problem is the adapter (yes, sometimes an unsupported HDD makes the system hang at detection). 128GB is the max I've seen some (very few) socket 7 motherboards handle. Just think that many PIII can't handle 128GB, it's too large for that time period.
e - Consider an earlier SATA PCI card, Promise is indeed good, as the 300 TX2+ doesn't have drivers for windows 98
f - Use some Dynamic Drive Overlay software, although I'm not sure what's the process to install it if the system hangs at disk detection
Reply 2 of 44, by Repo Man11
Jan has a patched BIOS for that board that supports up to 128 gigabyte hard drives: http://www.steunebrink.info/k6plus.htm
Reply 4 of 44, by mtest001
So I tried zo update my BIOS yesterday. I did not know that Awdflash 6.31 was known to sometime freeze/hang without notice and I learned it the hard way 😀 The tool just crashed right after erasing the current BIOS !
Now I need to salvage my BIOS ... I was not prepared for that but we'll see 😀
Reply 5 of 44, by gerry
mtest001 wrote on 2023-11-15, 08:28:
So I tried zo update my BIOS yesterday. I did not know that Awdflash 6.31 was known to sometime freeze/hang without notice and I learned it the hard way 😀 The tool just crash right after erasing the current BIOS !
that's why i never touch the BIOS in older machines, hope it turns out ok for you!
btw, ide to sd-card also an option
Reply 6 of 44, by dionb
The problem might not be with software, sometimes old EEPROM chips fail when writing. If you have (access to) an EEPROM programmer recovery is easy, otherwise you either need to try the bootblock procedure (needs a floppy drive and another working system to prep the disk) or hotflash on another board that can read & write this type of EEPROM.
If the EEPROM is dead, new ones can still be sourced, or pull one from a dead motherboard.
Reply 7 of 44, by mtest001
dionb wrote on 2023-11-15, 11:12:
Thanks, I'll try the bootblock procedure...
Reply 8 of 44, by mtest001
So finally after several unsuccessful attempts to get a 128 GB ssd hooked to my P200MMX@225 (tried 2 different SATA->IDE adapters and 2 different disks but I think those disks were simply too big or two recent), I switched to a CF->IDE adaper and a 16 GB CF and things worked just fine.
The only issue so far is that I cannot enable the DMA mode on the disk from the device manager of Windows98 se... But still the performance is slightly better than will old IDE HDD.
It's a nice upgrade, my HDD was only 4.3 GB... The CF is 4 x bigger !
Reply 9 of 44, by mtest001
I tried to lower the voltage on the CF adapter from 5V to 3.3V and still not able to enable DMA. Funny enough if I disable UDMA in the BIOS then in Windows the DMA checkbox is ticked.
Reply 10 of 44, by Chkcpu
mtest001 wrote on 2023-12-16, 22:45:
@Repo Man11: Thanks for promoting my patched BIOSes, again. 😀
@mtest001:
Great that you were able to recover from the bad flash!
About the UDMA issue, this is a BIOS bug as well. Here is the story:
Last year, when working on another i430TX board, I noticed that the BIOS summary screen indicated that the drives where running in UDMA 5 or 6 mode.
Because the i430TX chipset supports ATA33, any drive should be indicated as running in UDMA 2 max.
I’ve seen this before and always considered this a cosmetic issue and that the BIOS just displayed the capability of the drive and not the actual transfer mode.
However, I found that Windows 98 doesn’t like the BIOS reporting higher UDMA modes on older hardware and refuses to use any DMA mode when set in Device Manager. This results in a fall-back to PIO mode 4 with reduced Harddisk performance.
I’ve tested this on my i430TX board with an 11/1998 Award BIOS and a clean Win98 install, so I was using the standard Microsoft Bus Master IDE drivers.
Indeed the DMA mode would not stick and the atto disk benchmark measured a poor 9MB/s.
Luckily most Award BIOSes from 03/1999 or later have a fix for this UDMA bug and I found a way to apply this fix to older Award BIOSes as well.
I’ve tested this fix on my TX board and now Win98 allowed to select DMA in device manager and after a reboot I got 30MB/s in atto disk benchmark! 😀
Now that I have a patch for this UDMA bug, I will apply it to the next HOT-569 patched BIOS version as well. Just give me a few weeks to get it ready.
Cheers, Jan
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 11 of 44, by mtest001
Thanks for the feedback @Chkcpu and for proposing a fix, that would be very nice. I'll be happy to be the guinea pig for you 😀
It's a pity the BIOS settings for UDMA only propose "AUTO" or "Disabled", and there is no way to manually force it.
Reply 12 of 44, by Sphere478
Hey, try something real quick,
Change to 64mb of ram and see if the system is faster.
That chipset can only cache 64mb unless you go k6-3/3+/2+
Btw, some pmmx 200s had 3.5x unlocked. You can try 1.5x setting and see if you get 3.5x
@chkcpu, is that pio bug present on tyan s1564?
Sphere's PCB projects.
Reply 13 of 44, by mtest001
Sphere478 wrote on 2023-12-17, 23:46:
Yes, I am aware of this limitation, however I understand that the performance hit is relatively limited (see for example https://www.anandtech.com/show/96/2 - comparing the perfs between 64MB and 96MB). Now you are right perhaps it would be worth giving it a try to see by myself if there is any noticeable difference.
Good to know I may try this also. I still not have taken the time to test how far I can overclock that little P200, I thought 3x75 was a safe and conservative ratio.
Reply 14 of 44, by Sphere478
Most pmmx can do 250 if I recall from my tinkering
Reply 15 of 44, by Chkcpu
Hi Sphere,
No, the Tyan S1564 is not affected by this Win98 UDMA bug because the i430HX chipset uses the 82371SB (PIIX3) southbridge that doesn’t do UDMA. The same goes for boards with the i430FX and i430VX chipset.
So your S1564 will happily run Win98 in PIO 4 or MW DMA 2 modes via the on-board IDE channels.
Only socket 7 boards running a 02/1999 or earlier Award BIOS with UDMA supporting chipsets are affected by this bug. So boards with i430TX, ALi154x, SiS-5582/5591/5598, and VIA VP2/VP3/MVP3 chipsets to name a few. But you should be fine when running a 03/1999 or later BIOS on these boards.
It is possible that early Award BIOSes on Slot 1 boards are affected as well, but I have no data on that.
Cheers, Jan
Reply 16 of 44, by mtest001
Sphere478 wrote on 2023-12-18, 17:04:
That's possible, however I remember clearly my rationale back then for not pushing it too much: I needed my computer for my studies and, as a second level priority, for LAN parties, so I could basically not afford the downtime and budget impact of a toasted CPU 😀 Hence the conservative 3x75 MHz.
Reply 17 of 44, by b0by007
About the original post, I think you can still use that 160 gb hdd with the SATA->IDE adapter.
Using another pc and hitachi f tool, you can limit the hdd size. Try 32 gb, it should work.
https://files.hddguru.com/download/Software/H … FEATURE%20TOOL/
HP Vectra D2753A 486/25N i486 SX 25mhz
UNISYS SG3500 AMD486 DX2 66mhz
OLIVETTI M4 i486 SX2 50mhz
IBM PC 330 6577-79T, Pentium 166mhz
IBM PC 300GL 6561-350, Pentium II MMX 266mhz
My retro youtube channel!
Reply 18 of 44, by AlessandroB
mtest001 wrote on 2023-12-18, 22:00:
bah…. at that time i had a PII233 and a friend of me P233MMX at 83Mhzx3,5 (290Mhz) …. still work TODAY.
Reply 19 of 44, by Sphere478
let me expand on that remark 🤣, I recall some samples posting well into the 300s like 330mhz
250 is nothing, if it's stable, run it !!overclock!!:p
Pentium 1 Tillamook 266 ppga, those nutty bastards will do 400 mhz without breaking a sweat.
We recently confirmed some rare film chip units had 4.5x multi(66x4.5), and a 5x multi(90x5) was on the books but is as of yet unconfirmed within the community.
