First post, by caver99
i have trying to flash the xt-ide bios to an eptom to have in my 386 and i have run the xtidecfg and configured the bios and also ran checkit 3 to make sure i have a spare address.
i have ran the 3ccfg and enabled the boot rom at the spare adress space.
no the part that isnt working.
i have tried a 27c64 eprom, a 28c256 eeprom and a w27c512 eeprom and cant get anything to sow on the system
am i doing something wrong here.
Reply 1 of 4, by Jo22
Hi there! No, I don't think you did something wrong. But maybe one step is missing.
The XT-IDE ROM needs to be modified with the supplied XT-IDE utility first.
The utility (xtidecfg.com, for DOS) adds a checksum, which is required.
https://www.xtideuniversalbios.org/
You can try my old personal backups, as an alternative. They're old, but ready to use.
Re: IDE disk-on-module + 386
Edit: You already ran xtidecfg, okay..
Maybe it's also related to the PC or network card somehow.
The backups should work, though.
Reply 2 of 4, by douglar
I had the same problem, but I had some older simpler network cards that worked, so I just moved to the next card. I’d love to know what I did wrong.
Reply 3 of 4, by caver99
Jo22 wrote on 2023-11-15, 17:39:
Hi there! No, I don't think you did something wrong. But maybe one step is missing. The XT-IDE ROM needs to be modified with t […]
your backup worked for an at28c64, what chip did you use for the large one?
Reply 4 of 4, by Deunan
AT28C64 or AT28C64B? There is a difference.
Not all ETH chips guarantee that unused address lines will always be held high (RTL8019A does) plus the 3Com setup programs insists on testing the EPROM before accepting config changes.
Use B parts or even EPROMs instead of EEPROMs. If using bigger capacity chip make sure to fill the entire memory space with mirror copies of the data. And lastly make sure the part used is 150ns or better, and if it's older and used EPROM it could have degraded, look for 100ns or even 70ns to be on the safe side.
