First post, by InterClaw
Anybody know of a way to get DOSKEY to operate in insert mode, but still use the normal/small cursor? Whenever I'm in insert mode I get the tall, ugly cursor, like this is the special, out of the ordinary mode. I guess overwrite by default what the convention back then.
Doesn't matter if I've used the -i parameter or just hit the insert key. Insert mode always shows as a tall cursor.
I'm using MS-DOS 7.10 btw.
I know 4DOS supports this, but I'm having a bit of a problem with it, so I can't really use it.
Is there another way of accomplishing insert mode with a short cursor? Like a hacked DOSKEY.COM for this?
I saw a program called "CED" referenced here and I'd like to try it out, but the link is dead. Anybody know where I can find it?
Reply 2 of 14, by InterClaw
maxtherabbit wrote on 2023-11-19, 13:19:
The original MS version of DOSKEY doesn't do that. Only the enhanced DOSKEY packaged with CDU DOS 7.
Sorry, I was not clear enough. That's the version of DOS I'm using. Here are the checksums of my DOSKEY.COM:
  CRC-32: 3b1d7f49
MD5: d1f4f39e6c079a072acc43c12f0becec
SHA-1: 32291ac397de7bf30331b3bb1f1d3855edaccbea
SHA-256: 55586d8dca1f3de8c95236a6f056b69323ac481ba08a5d7770efc3d029023c1a
4 647 bytes, modified 2003-10-22 10:10:14.
The disk image it came from has this:
  CRC-32: 5296601c
MD5: e251849abfef735d659a280be0706c86
SHA-1: 7daaf83aa6bcc1bb7e4cc523ae93f56dfd160af4
SHA-256: 5b4244e7116acb1aeaba1ebc027e32836e111a7869adddc9bdd384bf53670793
1 474 560 bytes, modified ‎1996-12-25 ‏‎01:32:00.
It runs in overwrite mode by default. When run with the -i parameter (or I hit the insert key), the cursor becomes the tall one.
So I think you might be mistaken here. Or are we misunderstanding each other? Perhaps there is a more up to date version than the above then? I'm not sure if I'm allowed to link to where I got the above one.
Reply 3 of 14, by Gmlb256
The recent version of the enhanced DOSKEY with the source code can be downloaded here: http://paulhoule.com/doskey/
Still, it doesn't get the normal cursor when in insert mode, but you can make the changes to the source code to fix that and assemble it with JWASM.
Reply 4 of 14, by InterClaw
Gmlb256 wrote on 2023-11-19, 14:26:
That's a great tip! I've tried that version before and noticed it behaves the same, yes. It has a larger memory footprint, but it might be worth it if I can modify it.
I'm afraid my understanding of assembler is pretty limited though. 😁
Which do you think would be easier to modify? That insert is the new overwite (and vice versa), or to switch the look of the cursor for the two modes? I'm thinking the latter maybe. Either would be fine for me.
Reply 5 of 14, by Gmlb256
InterClaw wrote on 2023-11-19, 17:38:
That's a great tip! I've tried that version before and noticed it behaves the same, yes. It has a larger memory footprint, but i […]
Switching the look of the cursor between the modes is easier, I have just built a version that does exactly that to make life easier. The change is done in the dkres.asm file in the InitInsertMode procedure.
Add the -I command line switch and you're good to go. 😁
    DOSKEY.ZIP
    81.69 KiB
    20 downloads
    Enhanced DOSKEY 2.8 with the insert mode using the normal cursor.
    GPL-2.0-or-later
Reply 6 of 14, by maxtherabbit
InterClaw wrote on 2023-11-19, 13:54:
Yeah, I was actually thinking of the IBM version packaged with PC-DOS sorry
Reply 7 of 14, by InterClaw
Gmlb256 wrote on 2023-11-19, 18:43:
That's awesome! Thank you! I compared the .asm file to the original and saw your negation there basically. 😀 I had a feeling it was that file, but had no idea about the syntax.
The only downside with this version I guess is that each mode is still hardcoded to a particular look...
maxtherabbit wrote on 2023-11-19, 21:21:
... so it was with great interest I now also tried the PC-DOS 2000 version. This one even has a slightly smaller footprint than the MS-DOS version. The mode it is started in dynamically gets the standard cursor and the other mode (when hitting the insert key) gets the tall cursor. That's nice, but it does have some limitations this version:
- It does not have tab autocompletion.
- Parameters have to be written out with slashes and the full word, e.g. /insert. No short versions or dashes here.
- It has no unload routine.
It was nice to try it though. 😀
Reply 8 of 14, by Gmlb256
InterClaw wrote on 2023-11-20, 04:02:
You're welcome!
That was the quickest solution. A new command line switch can be added to toggle the cursor visualization but doubt that you will need it and I'm not a fan of insert mode getting a taller cursor in the DOS prompt as well.
Reply 9 of 14, by maxtherabbit
none of the original versions have tab auto complete, only the aftermarket "enhanced" DOSKEY, so I don't really think it's fair to call that a limitation
regarding the command line argument, who cares? isn't everyone loading it in AUTOEXEC.BAT anyway
Reply 10 of 14, by dr_st
My DOSKEY.COM is 15,495 bytes long, and if loaded with /INSERT switch, then the insert mode will have the default cursor and the overstrike mode will have the tall one.
I think it's the original Win98 SE DOSKey...
Reply 11 of 14, by InterClaw
maxtherabbit wrote on 2023-11-20, 14:43:
For sure! I was just motivating myself to run this modded version taking up more memory. 😀 I do believe it's worth it.
Reply 12 of 14, by InterClaw
dr_st wrote on 2023-11-20, 22:42:
Ah, okay. And that version was replaced by Enhanced DOSKEY then maybe for the CDU install version.
Reply 13 of 14, by InterClaw
It seems to me that the version of DOSKEY.COM that comes with MS-DOS 7.10 (CDU) is an earlier version of Enhanced DOSKEY circa 2005(?) when they were about 4k in size, but not [significantly] contributed to by Wengier yet then.
Today, version 2.8 is much larger and therefore naturally takes up more memory when it's running.
Reply 14 of 14, by Gmlb256
Most of the contributions from Wengier were around LFN support and increasing the default buffer size was among of them. The earlier versions can be still downloaded but the first one with the source code available is version 2.0.
