First post, by JF_Sebastian
Good morning folks,
as mentioned in my previous threads, I'm currently working on an Asus P/I-P55T2P4 Rev 3.10. In my search for a RAM upgrade, I came across the "HP A3398-60014" 128MB RAM module. It appears to be a 72-pin EDO RAM with 50ns timing and true ECC, but I can't find any more information about it - anywhere, not even on HP's homepage. Does anyone have experience with these modules and whether they are compatible with the P55T2P4? According to the manual, the MoBo should support ECC.
Many thanks in advance!
JF
Boot Up or Shut Up!
________________________
Asus P/I-P55T2P4 Rev. 3.10
Asus USB/MIR Rev. 1.11
AMD-K6-III/450AFX @6x83MHz; 2.4V
4x128MB EDO RAM 60ns
MATROX Mystique MGA-1064SG-D 4MB
Diamond Monster 2 8MB
DELOCK 91620 - CF to IDE
Reply 1 of 5, by mkarcher
This modules is kind-of special, because it has four banks of 32MB each, but while PS/2 SIMMs can be "double-sided" by design, they can not be "quad-sided". So this module uses 6 12-bit switches to select which "bank pair" should be accessed. While the design of this module might try to be transparent to the host about the "quad-bank" design, I have no idea how they could implement that without another (custom) logic chip, so there are reasons to believe that this module is not a standard "36-bit PS/2 module", but some very special HP kind of PS/2 module that requires dedicated mainboard support.
Most likely, it will not work on a consumer-type mainboard, even if it is "pro grade" like the P55T2P4.
Reply 2 of 5, by luckybob
There are a few on ebay for ~$20 each
Try it out. grab a pair and see what happens. it looks like a ecc/reg simm. So another issue is mainboard compatibility with registered ram. Some chipsets are okay with it. Some are NOT. I dont recall about the 430HX.
Third. the 430HX chipset is DOG SLOW if the mainboard does not have a provision to upgrade the tag ram. Check this first. If you cant upgrade the tag ram, you should keep this chipset at 64MB of ram (or less)
Reply 3 of 5, by mkarcher
luckybob wrote on 2023-11-23, 18:33:
It's not registered. The CBT16212 chips are no latch chips, as would be required for a registred SIMM. Also, the CBT16212 chips are no buffer chips, as would be required by a buffered SIMM. They can be used as 24 on/off-switches, or 12 A/B switches, but don't provide any active signal processing.
Reply 4 of 5, by luckybob
oh, i did not look that carefully at the HP simms.
If that is the case, I would bet the house they are only going to work on specific HP systems. And I would not be surprised if they caused damage to non-hp equipment.
Reply 5 of 5, by JF_Sebastian
Hello folks,
thanks for your quick replies. I'll just buy a pair in the bay and give it a try. No risk - no fun. I bought a P55T2P4 on ebay a few weeks ago for very little money, it looks very badly aged and I had to repair it on the I/O chip to get it working again. So it's a good patient for the test.
I'll let you know if it works 😉
Best regards,
JF
Boot Up or Shut Up!
