First post, by lepidotós
- Member
As a reminder: Athlon 750 (or 700, may downclock it just so it doesn't get so hot to hopefully extend the life of it), KX133 on an Asus K7V, and I plan on running Mandrake 8.2, Fedora Core 3, and Windows NT 5.0.1796 just for the variety of it and to try it out to see how far it can go. I used to daily drive Whistler 2419 in a VM for a few months when I was 15 and use ReactOS occasionally, so I'm comfortable tiptoeing around beta quality OSes' seams.
I own both cards already, and they're sitting next to me (and each other) on my desk right now, so it's not a question of which to buy, just which works out better -- I've heard the Audigies are more stable on Intel PCs, but if it works fine as it is on AMD and sounds better than the Live! (or the as far as I can see completely not there onboard audio), I'd prefer it. The Audigy has a 1394 under the Audigy wordmark and colored outputs, which from looking around I'm pretty sure means it's an OEM card, and I don't really know if that means it needs any special considerations, I've seen it go either way on forum posts before.
Of course, this all becomes moot if the Audigy (or the Live!) doesn't work -- I bought it from a thrift store when I was like 14, so it's been a little while and I haven't had the opportunity to test it out until now, though as far as I remember the Live! did claim to work when I bought it off eBay. Still, considering both cards look pretty good, no obvious burst caps or chips with discolored spots, I'm going to assume they work until proven otherwise.
Thanks for the advice.
"I have to blow everything up! It's the only way to prove I'm not crazy!"
—Dr. Gordon Freeman, May 2000
