First post, by detritus olentus
- Member
I am trying to get an internal zip drive working on a no-name Headland 286 board with a Harris 20mhz 286. So far I have had no luck setting the zip drive to slave on the primary and only IDE on the multi IO card. Tried using a Siig Cn2424 with dual IDE controller but this doesn't see my CF card hard disk. No luck getting it to show up using the Sound Blaster CT2290 IDE controller. Added a Future Domain single IDE controller but no luck there either. All of my attempts have been using Guest.exe 6.0 to attempt to assign a drive letter to the zip drive. Have tried 2 different zip drives with no luck. Any advice appreciated.
https://archive.org/details/@detritus_olentus
Philly Burbs.
