First post, by boby
I have a San Li SL-586V motherboard with Intel 133 MHz working on it. The board: https://theretroweb.com/motherboards/s/san-li-sl-586v
I want to replace my Intel with Cyrix 166+
According to the manual on the net this CPU uses same jumper settings as intel I have. So I didn't change anything, but all I get is constant fast beep sound.
Anyone have any idea what it could be?
Reply 1 of 10, by aitotat
That is 6x86L using 2.8volts. You need regular 6x86 for that board since it almost certainly won't support 2.8v since it uses FX chipset. Those usually need the voltage module for that. But if your board supports dual voltage, make sure the voltage jumpers are correct.
Reply 2 of 10, by boby
aitotat wrote on 2023-11-30, 18:49:
According to this I should have J1 as Pins 2 & 5 closed and J12 Pins 2 & 4 closed, But here is the problem. On my board I have shorted jumpers 1 & 3 with soldered wired. So I can change J1 but not J12.
Should I dare to desolder that wire and short the other 2 pins?
Reply 3 of 10, by aitotat
My guess is that your board revision doesn't have necessary VRM for other than 3,3V. That is why there is no jumper but soldered wire.
Reply 4 of 10, by boby
aitotat wrote on 2023-11-30, 19:33:
What would happen if I solder the wire on 2nd position? According to the manual, those should be 2.8V.
Can I burn the board this way?
Reply 5 of 10, by rmay635703
Cyrix chips use more electricity than Intel, occasionally the 166+ would be borderline on early boards overloading the vrm.
Also Using straight 3.3v could fry the 2.8v chip
There is also a compatibility issue with the 2x multiplier on early boards in that 2x was physically wired wrong for socket 7 chips
Reply 6 of 10, by boby
rmay635703 wrote on 2023-11-30, 20:35:
I already tried 3.3V with this cyrix, but as it still beeps, I hope it is still alive.
What if I wire this other pins that should be 2.8V? Can I fry the board?
Reply 7 of 10, by boby
Actually shorting the other pins made my Cyrix to boot 😀
Turned it on just for short, now I need to test for stability.
Reply 8 of 10, by MyJules
boby wrote on 2023-12-01, 12:53:
which pins did you short to get it work???
Reply 9 of 10, by boby
MyJules wrote on 2024-03-28, 14:29:
There were 2 pins shorted with wire and 2 other empty pins, next to it. Not really the pins, more like holes in the board.
I removed the wire, and put it to the other 2 pins.
IMPORTANT: my pins layout might be different from yours. For my board I found that those pins are suposed to have different voltage then the shorted ones, so I give it a try.
Unless you have the same board, you should be careful.
Hope this helps
Reply 10 of 10, by MyJules
thx 😀
