First post, by 3lectr1c
- Member
My ThinkPad 385XD's CD-ROM drive appears to be developing a failing laser, it used to boot fine off burned disks, now it won't even reliably read them at all. It will still boot from pressed ones but I don't have 98SE on official media, only 98FE, and I'd like to clean install Windows again due to a few problems with the old install (hard drive is fine).
I think in this case I'm just going to install using a different computer, move the hard drive back over and sort out drivers, but for the future, how come I can't get installation off the hard drive to work? I've done so with 95 with so problems.
I have a FAT32 formatted 4GB HDD, formatted on modern windows (could be an issue but I doubt it). I copied the contents of the 98SE CD image onto the drive in a subfolder. Then, I booted to DOS from my 98FE CD that actually works in the drive and started installation off disk. It gets through scandisk fine (which is why I think the format is fine) then fails quickly with error SU0013 saying it cannot create files on your startup drive and cannot set up windows 98.
Format issue?
Owner of https://www.macdat.net, the largest vintage laptop documentation resource on the web!
