First post, by ayandon
Hello Friends,
Yesterday, I found this Biostar M5VNB Socket 7 motherboard from a dealer.
This one - https://theretroweb.com/motherboards/s/biostar-m5vnb
But, in my un-experienced eyes, I can guess that these few Caps are missing! Because they have marks on the PCB.
  • I have marked the missing Caps as YELLOW. (Right-Top most Cap size is smaller)
  • RED marked Cap which is very near to the missing Caps is of 1200uF 6.3V.
  • GREEN marked Caps are of 1000uF 6.3V.
file.php?mode=view&id=180002
Pls suggest -
  • What Caps should I put there? (Right-Top most Cap size is smaller)
  • DO you find any other issue or missing components in the board?
I can't find any reference picture in the Internet 🙁
P.S. I checked the motherboard and there seems to be no short issue.
I want to restore my late father's 1st ever computer IBM ET&T PC-XT that he gifted me.
Hope you will be kind enough to guide and support me to restore his loving memory.
Reply 1 of 4, by majestyk
I´d suggest you add 1000µF 6.3V (3x) or 10V where the smaller footprints are and 1200µF 6.3V or 10V (5x) where the larger footprints are.
Don´t forget the two at the top right corner.
Reply 2 of 4, by ayandon
majestyk wrote on 2023-12-03, 14:54:
You´ll need a BIOS chip also.
Thanks for the suggestion.
Thanks for noticing that two at the top right corner, I missed it.
Yes, I have the BIOS chip. I gave it to a friend who has the programmer to read and backup the BIOS.
Reply 3 of 4, by ayandon
The only pic I can find to compare -
Reply 4 of 4, by giantclam
Same pic I found.... and going by that;
Looks like these 2 caps have been removed because leaking --- they will be the same value as the cap that's still there...
...capacitors at top right, are 'no-stuff' ... capacitors were never installed... this is normal.
Other capacitors you've highlighted will (or should) have values marked on them.
