First post, by hadi0990
Hi Guys
I'm Recently Got Asus P4S800D-X
Good And Little Dusty Condition
Bios Version It's 1003
And I Don't Have Floppy Disk
So How Update Bios On This Motherboard? Becuase I ordred Pentium 4 3ghz(SL7PM)
The BIOS version on the motherboard may not recognize this CPU at all
Reply 1 of 12, by dominusprog
With the EEPROM programmer. But if it's working correctly leave it be.
https://www.ebay.com/itm/313335729350?hash=it … %3ABFBMhNqSy4Zj
OPTi MAD16 / Creative Vibra16XV ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 3 of 12, by Repo Man11
If your motherboard can boot to a USB drive, that would be the easier way to go; but I doubt that is an option on that board. This link has instructions on how to create and use a CDRW for updating the BIOS, so hopefully you have one, or can get one for a reasonable price. https://www.biosflash.com/e/bios-boot-cd.htm
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
Reply 4 of 12, by PC Hoarder Patrol
hadi0990 wrote on 2023-12-04, 14:05:
dominusprog wrote on 2023-12-04, 12:01:
Can Be Update bios By uniflash?
Becuase I'm Living In Iran And Programer EEPROM Are Not Avalible On My Country
According to the Asus support page 3.00GHZ/1M/800 spec processors have had BIOS support since 1002, so you should be OK
Reply 5 of 12, by dr_st
Repo Man11 wrote on 2023-12-04, 16:22:
Why not? USB boot was pretty standard in the late Pentium 4 era. In any case, CD-R/RW will work as well.
I second that.
Reply 6 of 12, by hadi0990
let's try and see what happens
Reply 7 of 12, by Karbist
Not exactly the same model but P4P800-X boots fine from a USB drive, so this one should boot too.
Reply 8 of 12, by darry
One can boot into DOS (including Windows 9x bundled one) from an IDE hard drive and run the flasher from there.
Reply 9 of 12, by Repo Man11
dr_st wrote on 2023-12-05, 19:12:
Why not? USB boot was pretty standard in the late Pentium 4 era. In any case, CD-R/RW will work as well. […]
I second that.
I just checked, and my mid Pentium 4 era Amptron M930LR allows you to boot from a USB floppy drive, and I was able to do so. It also has the option to boot from a "USB HDD" so it ought to be able to boot from a USB thumbdrive that's the correct size and file format. Best option if available.
Reply 10 of 12, by hadi0990
Can Boot From Usb
And Booted to Freedos And MS-DOS
Reply 11 of 12, by hadi0990
Thank you all for your help in updating the motherboard bios
thank you Guys
It's Worked
I appreciate your comments
But I can update to the latest version of BIOS which is beta, I mean it is beta
Is there any problem in terms of stability and so on?
Reply 12 of 12, by Repo Man11
hadi0990 wrote on 2023-12-19, 13:28:
Thank you all for your help in updating the motherboard bios thank you Guys It's Worked I appreciate your comments But I can upd […]
thank you Guys
It's Worked
I've seen (and used) many end of the line BIOS updates from Asus that were classified as beta, but I've never had an issue (that I'm aware of) caused by this.
