First post, by Robbbert
I've noticed that mouse wheel is not supported on a standard build of Windows 95 or on NT 4.0 .
I tried downloading a few random drivers off the net but none of them worked and one of them even made the computer go crazy so I had to remove it.
One of the NT computers had a driver by the name of Fellowes installed and that works perfectly, however I'm unable to locate the installation program anywhere.
What driver(s) would you suggest? It's a standard PS/2 mouse with scroll wheel that you could buy in a shop currently.
Reply 1 of 5, by dominusprog
Why not use the official driver? What is the brand?
Aztech Pro16 II-3D PnP ❇ 8.4GiB Quantum Fireball ❇ Win95 OSR2 Plus!
Reply 2 of 5, by Joseph_Joestar
Robbbert wrote on 2023-12-04, 11:47:
I think Microsoft's Intellimouse driver can enable the scroll wheel under Win95 even for non-Microsoft branded mice.
Try this version from Vogonsdrivers.
Reply 3 of 5, by Robbbert
@Joseph_Joestar : That worked both on NT 4.0 and on Win95, thank you very much for the suggestion. 😀
Reply 4 of 5, by maxtherabbit
Best method for NT4 is to use no additional driver and edit the registry to fix it.
See here:
https://www.itprotoday.com/compute-engines/js … el-not-detected
If you have a PS/2 Wheel Mouse without special driver (IntelliPoint or 3rd party), and the wheel is not functional, it is probably not being detected. Browse to:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\i8042prt\Parameters
Edit or Add Value name EnableWheelDetection, a type REG_DWORD, and set the data to 2.
Reply 5 of 5, by Robbbert
I still have 2 NT machines that haven't been done yet, so I'll try that idea whenever I get around to it. Thanks for the suggestion!
Also, I recently found the Fellowes driver that was on the original post, just downloaded and saved so far.
