First post, by zwrr
I have a BEK P407 motherboard, it suddenly doesn't boot properly, the screen doesn't show anything after the power is turned on, the beep is very strange, I tried to change the graphics card, memory, etc., nothing changes.
Can someone please tell me the meaning of this beep code?
The attachment BEK P407 蜂鸣代码 .mp3 is no longer available
Pentium MMX233, Zida TX98-3D, 64MB, Riva 128, Aztech Waverider Pro 32-3D, HardMPU-wt
K6-III+550, FIC VA-503+, 256MB, Voodoo3 2000, Creative AWE32, HardMPU-wt
Tualatin-1.4G, QDI A10BM, 512MB, G400, Voodoo2 SLI, Creative AWE64
Reply 1 of 4, by Horun
Sounds like: One long two short then a failure buzz-beep.
Typically a Video error beep code but I would check your PSU to make sure it is providing proper volts before doing anything else -> assuming it all was working properly and re-try the original parts again.
Reply 2 of 4, by NHVintage
I don't suppose your cmos battery is dying? If you unplug it from power for a little while do you lose your bios settings?
Reply 3 of 4, by zwrr
Horun wrote on 2023-12-05, 02:50:
I tried multiple ISA and PCI graphics cards, Trident 8900C, 9000i, GD5422, S3 Trio 64V+, etc., and nothing changed.
Regarding the PSU, I also replaced it and can confirm that the PSU works fine on other motherboards.
Reply 4 of 4, by zwrr
NHVintage wrote on 2023-12-05, 03:11:
I tried removing the CR2032 battery and nothing changed, black screen and alarm and that's it.
