First post, by keenmaster486
I have two printers hooked up right now: an HP Deskjet 842C, and an IBM 5152 Personal Computer Graphics Printer (Epson MX-80).
Each of them is hooked up to a different system. The Deskjet is connected via USB to my primary modern computer and via parallel to a 386 machine, while the 5152 is connected via parallel to my IBM PC 5150.
None of these computers are electrically connected in any way except through the network - all three are wired via into my home network.
I believe they are also all on the same power circuit.
The Deskjet ordinarily sits on and idle waiting for a print job.
Here's the strange thing: if I walk over to the 5152 and turn it on, the Deskjet will wake up as though it has begun receiving a print job. It will then flash the out of paper light. If I press the paper button, it feeds a single page through without printing anything.
I tried various combinations of disconnected cables and determined by process of elimination that a signal is traveling through the power lines from the 5152 itself (not through the 5150) to the 386 computer, then through its parallel port to the Deskjet.
It's really bizarre. Has anyone else ever encountered this type of behavior?
World's foremost 486 enjoyer.
Reply 1 of 19, by debs3759
You have a poltergeist living in the 5152 !
Reply 2 of 19, by DrSwizz
I have a PC that often wakes up sleep mode when I turn another device nearby. It is a modern computer and I use cheap USB-to ps/2 converter so I can use an old AT keyboard with it. Likely the USB-to ps/2 converter is lacking proper shielding so whenever a current is induced to it from the outside it signals that as key being pressed on the keyboard to the computer.
Reply 3 of 19, by Jasin Natael
Are the printers shared with the other PC via Windows?
Reply 4 of 19, by progman.exe
Electro magnetic interference in the USB, probably. Maybe. Dunno.
Any description of a bizarre thing is a bit hard work to read. The USB printer jumps into life when the old machine is switched on?
What happens if you just disconnect and reconnect the USB on the printer? Does it jump into life in the same way?
I have two computers here that suffer from USB keyboards vanishing, almost certainly due to EMI, Linux says so sometimes.
I use a thing called inputexec on a couple of Linux machines to make a keyboard into a one-press for an action, a monitoring computer and the kitchen music player.
The monitoring computer is near some poor shielded transformers (in plastic, not metal), and if they switch on/off then a USB keyboard can have a disconnect/reconnect event. That makes inputexec exit. Investigating that problem led me to USB/EMI problems. I bodged a solution by putting inputexec in an infinite loop with a sleep (some readers will have had their cringe gland implode seeing that, sorry).
The kernel messages also sometimes suggest EMI is the problem.
The kitchen music player can have a keyboard disconnect/reconnect when I run a new washing machine, probably because of the motor or a 2kW heater turning on and off.
Moving the transformers further from the monitoring machine helped, as maybe did buying a shielded USB cable. The kitchen computer I just ctrl-alt-del reboot it if the keyboard stops working with inputexec.
Could be some kind of jolt down the power, could be LAN, but I think induced power in the USB from an old computer. Ahhhh, got an old CRT on that? Big, inefficient electromagnets!
Reply 5 of 19, by Jo22
Some form of sheath current, maybe? 🤷‍♂️
https://en.wikipedia.org/wiki/Sheath_current
Reply 6 of 19, by ElectroSoldier
Curious little "problem"
If they are both booted without any network connected does the same thing still happen?
Reply 7 of 19, by midicollector
Maybe some kind of wake on lan behavior?
Reply 8 of 19, by PD2JK
Are the printers shared on the network through any of the systems?
Run Wireshark and capture some frames when it occurs to rule the network out. Look for broadcast packets.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 9 of 19, by DerBaum
keenmaster486 wrote on 2023-12-05, 16:46:
Maybe the problem is the connection via .
FCKGW-RHQQ2
Reply 10 of 19, by Jo22
I suspect an AC related issue. Maybe some sort of ground loop, a power peak/current peak.
In many cases, cheap switching-psus are a culprit.
The invention of the switching-psu caused more trouble than it's worth (imho)..
Edit: If it's a ground loop issue, turning the power plug may help.
Reply 11 of 19, by kingcake
Network cards (Ethernet, anyway) are isolated on each end using transformers. Often referred to as "magnetics" in network card parlance. This is done to prevent ground loops, etc.
Reply 12 of 19, by BitWrangler
Jasin Natael wrote on 2023-12-05, 17:22:
Yah I'd suspect windows restarting the print service when it detects printer or something doing it.
Reply 13 of 19, by Jo22
kingcake wrote on 2023-12-05, 18:57:
Yes. Power supplies, too, if they are the good linear type with a transformer (and are not tying both grounds together).
Unfortunately, switching-psus are often badly made. Just look what's inside USB wall psus. They're often terrible designed and righteous dangerous.
Sometimes, there's a 60Hz/50Hz signal reaching the DC side, for example.
Edit: I've checked the inter webs, the MX-80 has a traditional PSU. So far so good.
*If* it's the culprit for the malfunction, a new set of capacitors may help to provide cleaner DC power.
Edit: It's not just the electrolyte caps, but the filter caps on the AC side.
Historical, these filtering caps often fail after a longer period of time.
https://mansfield-devine.com/speculatrix/2018 … -friend-part-1/
But maybe the problem is the other printer, also.
It might be possible that RF noise emitted by its PSU sneaks into the parallel cable somehow.
Depending on its lenght and physical location, it might act as an aerial for all sorts of RFI.
Adding ferrites to the cable may help.
Reply 15 of 19, by Jasin Natael
BitWrangler wrote on 2023-12-05, 18:58:
Yep, pretty much what I was getting at.
Reply 16 of 19, by Jo22
^@DosFreak Thanks, YMMD! 😁
Jasin Natael wrote on 2023-12-05, 21:33:
What does the LED on the ethernet card inside the 5150 say?
If there's an imminent activity happening in same moment, it should flash or change blinking pattern?
PS: An oscillograph (scope) would really be helpful here. It could be used to visualize the data stream on the ethernet cable, as well be helping to check the AC line*.
Edit: A so called "logic analyzer" would be helpful for the checking data stream, too. Some modern scopes have it built-in.
*Probing the AC line is dangerous and not recommended for the novice.
It can help to check mains quality, though. If there's any RF noise on the power line.
Reply 17 of 19, by giantclam
1 host | 1 printer ..... I could be wrong, but I think that's non-standard hookup (unless of course the deskjet manual says you can hookup 2 hosts to the 1 printer)?
Reply 18 of 19, by keenmaster486
I forgot to mention that this happens whether the computers are on or not - although I haven't tried it with the 386 on. I suspect if I turned it on, it would actually stop happening.
It's definitively going through the AC power lines. I've verified that.
Yes, probably bad filter caps somewhere or something (perhaps in the 386's PSU), it's just bizarre that it causes the Deskjet to think it is receiving a new print job.
Reply 19 of 19, by kingcake
Is it possible you're having very quick brownouts? If the voltage sags below a certain point the switching power supply will restart, or the watchdog will reset the device.
