First post, by avatar_58
- Oldbie
Ok, I realize this is the dosbox forum however since dfend does not yet have a forum and you guys are knowledgable I thought this would be a good spot to ask. If not, move it to correct forum π
Anyway..
I have a few hundred games for dosbox to emulate now and I setup D-fend with every one of them. I plan on making a DVD with the configs and profiles all setup so that I can avoid having to install them over again.
My problem? D-fend is beginning to have issues. I don't know if its being caused by having one too many games in the list (since it refreshes alot) but for some reason it will occasionally "loose" its config and ask me to locate dosbox! π³ This also resets all of d-fend's defaults and configs that I changed. The game list stays intact (thank god...) however I have to enter in all the dynamic options and wizard defaults all over again.
Anyone understand why this occurs? I don't crash d-fend or anything when I exit so that can't be it. The only thing I've done is load it with profiles π
